It is currently Mon Jul 14, 2025 9:02 pm
 Post subject: Faulty Diaphram?
PostPosted: Thu Feb 09, 2006 11:34 am
No she's not pregnant :)
The Moke was driving fine except for some throw out bearing noise and a minor primary gear seal leak. All of a sudden the clutch stopped working.
OK we took the motor out and found the primary gear was stuffed. Replaced it, replaced seal, replaced trow out bearing. The clutch plate was fine no contamination at all.
The hydrolics are fine, the clutch arm moves correctly.
Whacked it all together and no clutch and the pedel is really soft.
Stuffed diaphram?
PostPosted: Thu Feb 09, 2006 1:07 pm
As far as I know, if the diaphragm has given up the ghost, you would have felt alot of shuddering when taking off.
You did put the friction plate back in, didnt you??? :P
PostPosted: Thu Feb 09, 2006 1:30 pm
damn... i was going to say awdmokes mum had one of those..
