HELP!!!! my mini is sick https://www.ausmini.com/forums/viewtopic.php?f=2&t=1603 |
Page 1 of 2 |
Author: | NAV [ Fri Aug 20, 2004 4:38 pm ] |
Post subject: | HELP!!!! my mini is sick |
When at the lights or on over run theres a cloud of oil smoke ![]() the engine is only fresh from a re-build. I took of the hose that goes to the carb from the back of the block and there was vapour coming out of it. It felt oily, so could it be i've got bad blow by or the crank case vent thing is knackered? or both? help cause i'm outta my depth here and want to get an idea as to whats going on so i can take it back to the engine builder and tell them what's up so i don't get the run around |
Author: | 68matic [ Fri Aug 20, 2004 5:35 pm ] |
matt im guessing its something called a PCV positive crankcase valve. it takes the air from the crankcase (crap fumes, vapour, water) and is supposed to feed it into the carby manifold do you have one of these its a saucer shaped thing that you can see here (cut n paste) http://www.angelfire.com/mech/ducho/engine_bay.JPG the silver thing in the top right hand side of the pic, hose coming out to inlet manifold i suggest you get yourself a new diaphragm, it should be soft rubber, about $7 |
Author: | NAV [ Fri Aug 20, 2004 6:44 pm ] |
mine is a tube looking thing that is joint to the inpetion plate a the back of the motor on the right then up to the hole on the left side of the carb after the throttle body. with anyluck the canister thing has just carked it but don't want to risk driving till i get a better idea of whats going on |
Author: | Anto [ Fri Aug 20, 2004 7:31 pm ] |
I wouldn't have thought the ventilation would be at fault, or at least not causing the smoke. Smoke out of the vent pipes = blow by. The engine is meant to breath, so vapour comes out etc, but smoke is bad. Mine used to puff a hell of a lot out the top, but it only ran on 1.5 cylinders ![]() Did it happen all of a sudden, or gradually? Who built your engine? |
Author: | 68matic [ Fri Aug 20, 2004 11:39 pm ] |
aaron and taryn and aiden's van blew smoke after a rebuild. they put 2stroke lawnmower fuel in |
Author: | gafmo [ Fri Aug 20, 2004 11:57 pm ] |
Just a quick question what Oil are using ![]() |
Author: | min13k [ Fri Aug 20, 2004 11:59 pm ] |
was the head recoed ??? is it smokey when you first start it of a morning makka |
Author: | gafmo [ Sat Aug 21, 2004 12:01 am ] |
Another Idea did you run the engine inn or did you rang it straight from the start |
Author: | 9YaTaH [ Sat Aug 21, 2004 9:48 am ] |
Post subject: | Any Changes? |
Hi Matt, How long ago was the engine overhauled? If the engine was fitted professsionally - get it back there quick! Did you change anything like the Rocker Cover cap? The "what oil" question is important - too slippery like a synthetic and your engine bores/rings have difficulty getting together - did you follow the engine reco fella's recommendations? You haven't overfilled the sump? Plus what everyone else has said.... PM sent ![]() |
Author: | 9YaTaH [ Sat Aug 21, 2004 10:01 am ] |
Post subject: | Smoke on the Water!! |
Oh, and have you checked that the white stuff is definately coming out the tailpipe? Otherwise it could be something as simple as a side plate gasket leaking oil onto the manifold? Clutching at straws now..... ![]() |
Author: | NAV [ Sat Aug 21, 2004 10:18 am ] |
Engine was running fine till yesterday. Still makes good power (for a 998) and the oil i'm using as reccomended by the engine builder (Morwood motors) is Castrol GTX 2 which was just changed the day before and the level is spot on full. Ok just been down stair to look at it (no name yet bastard springs to mind though) in the light and here's what i found. Plug on no#1cyl light brown Plug on no#2cyl black & oily ![]() ![]() ![]() ![]() Plug on no#3cyl light brown Plug on no#4cyl light brown going from rad side to clutch. It was also missing 1lt of coolant. Was checked that morning and level was ok. So it looks like i got my first weekend off in ages and i got no mini ![]() Back to morwoods on monday for a warranty claim i picked up the engine on the 27th of may so it is still covered (i hope) |
Author: | NAV [ Sat Aug 21, 2004 10:20 am ] |
Post subject: | Re: Smoke on the Water!! |
9YaTaH wrote: Oh, and have you checked that the white stuff is definately coming out the tailpipe?
Otherwise it could be something as simple as a side plate gasket leaking oil onto the manifold? Clutching at straws now..... ![]() Nah Mick it only leaks from round the rod change and at about 1 drop a day ain't gunna cause that much grief |
Author: | 9YaTaH [ Sat Aug 21, 2004 10:33 am ] |
Post subject: | Ouch! |
Matt Colman wrote: Engine was running fine till yesterday. Still makes good power (for a 998) and the oil i'm using as reccomended by the engine builder (Morwood motors) is Castrol GTX 2 which was just changed the day before and the level is spot on full. Ok just been down stair to look at it (no name yet bastard springs to mind though) in the light and here's what i found.
Plug on no#1cyl light brown Plug on no#2cyl black & oily ![]() ![]() ![]() ![]() Plug on no#3cyl light brown Plug on no#4cyl light brown going from rad side to clutch. It was also missing 1lt of coolant. Was checked that morning and level was ok. So it looks like i got my first weekend off in ages and i got no mini ![]() Back to morwoods on monday for a warranty claim i picked up the engine on the 27th of may so it is still covered (i hope) So have tried another plug and that you are getting good spark to number two?? The fact that the plugs are all "brown" makes me suspect the head - a valve guide seal - did Morwoods do that up as well? Brown? our wet with reddish unburn't fuel?? that could mean maybe an ignition problem....or a red herring!!! Don't listen to me ![]() |
Author: | 9YaTaH [ Sat Aug 21, 2004 10:38 am ] |
Post subject: | Head Gasket?? |
It was also missing 1lt of coolant. Was checked that morning and level was ok. Could it have got really hot?? Could it be a head gasket problem? Checked the water for contamination? I have to get off the net now - good luck - check your private messages Mick over and out... ![]() |
Author: | NAV [ Sat Aug 21, 2004 10:39 am ] |
Post subject: | Re: Ouch! |
9YaTaH wrote: So have tried another plug and that you are getting good spark to number two?? The fact that the plugs are all "brown" makes me suspect the head - a valve guide seal - did Morwoods do that up as well? Brown? our wet with reddish unburn't fuel?? that could mean maybe an ignition problem....or a red herring!!! Don't listen to me ![]() Ignition is fine as i said earlier runs sweet after it clears that crap out of it. I.e Cold you'd swear it was diesel (chug chug chug) but once it is warm it runs smooth I'll wait till monday throw it on the tilt tray and take it to morwood motors (Sigh) I WAS going to the coast but now.......................... |
