It is currently Sat Jul 26, 2025 4:54 pm
 Post subject: Paint stripper
PostPosted: Fri Feb 10, 2006 6:13 pm
Can anyone recommend some good brands? And where to buy.
I've got some cheap stuff from bunnings. Doesn't seem to do very well, glad wrap or not.
How much did you use stripping a mini?
 Post subject: Re: Paint stripper
PostPosted: Fri Feb 10, 2006 8:33 pm
CAM
Brown Clubman wrote:
aaron wrote:
What type of paint stripper did you use? Would be handy to know. Aaron
"CAM Camstrip Automotive Paint Stripper"
4Lt for $30.
A good invesment in your sanity as well as you're car's metal. Minimum scraping requjred!!
I bought this from Kevin Denis Holden Spares division in Western Hwy Sunshine VIC.
BC.
PostPosted: Sat Feb 11, 2006 1:16 am
NAV-MAN
Any automotive paint supplier will have some good stuff on the shelf.
If you can get your hands on aircraft grade stuff go for it thats some potent stuff that.
PostPosted: Sat Feb 11, 2006 7:09 am
Hi
I'm stripping mine at the moment as well. The stripper i'm using is from Septone ( super cheap auto) it's worked well for me ,it's taken it of in one hit you've just got to make sure you rough the surface up first so it gets under the paint. I just ran over it with 80Grit sand paper.
Have fun :P
