Wheel Bearings https://www.ausmini.com/forums/viewtopic.php?f=2&t=16069 |
Author: | Smarty [ Fri Feb 10, 2006 10:17 pm ] |
Post subject: | Wheel Bearings |
Does anyone know what the part numbers are for the wheel bearings on a 74 clubby? Also are they Tapered or roller? hmm just thought I would replace them. Any help would be appreciated. |
Author: | drmini in aust [ Sat Feb 11, 2006 5:40 am ] |
Standard front wheel bearings are now GHK1018 $53.01/pr includingseals. These are angular contact ball type. I think old part no was 16LJT 1-1/4 then 16LJT 31.75 The Cooper S tapered roller kit will fit too, latest p/no is GHK 1140 $60.42/pr including seals. These prices are for 1 side only, you need 2 kits. I only use the taperred roller kits now, they last far longer and have about 2x the load capacity. ![]() |
Author: | Smarty [ Sat Feb 11, 2006 7:06 am ] |
Thanks Dr Mini ![]() |
Author: | Smarty [ Sat Feb 11, 2006 7:09 am ] |
Where is the best place to buy them from? |
Author: | drmini in aust [ Sat Feb 11, 2006 7:41 am ] |
These prices were from my Karcraft catalog. www.karcraft.com.au email [email protected] ![]() |
Author: | simon k [ Sat Feb 11, 2006 10:20 am ] |
try a general bearing place like SKF if you have one nearby - they tend to be cheaper, and they list the same kits |
Author: | Mick [ Sat Feb 11, 2006 11:22 am ] |
If you pick them up from UK Minispares as "Classic Wheel Bearing Kits" they are Timken taper roller bearings by default. I paid 25 dollars a side a couple of years back, but that was then. Mick |
