Wheel big issues https://www.ausmini.com/forums/viewtopic.php?f=2&t=16138 |
Author: | Pin4e [ Mon Feb 13, 2006 1:27 pm ] |
Post subject: | Wheel big issues |
Ok the engineer wont pass 13" by 7" wheels on my van because they are more than an inch wider than standard ![]() ![]() |
Author: | 1071 [ Mon Feb 13, 2006 1:59 pm ] |
Maybe you could point out that later model Minis with the same (or very similar) suspension components came factoy fitted with 13X 6 wheels... Cheers, Ian |
Author: | =twista= [ Mon Feb 13, 2006 2:23 pm ] |
chuck on some old stockie wheels that fit well inside the flares. onced past and rego'd pull em off and put ur other 13s back on. They can defect you even if the side wall of the tyre is outside the flare, in which i believe is wrong because the side wall doesnt flick stones up because there is no tread, but thats how they do it. |
Author: | mad-mk1 [ Mon Feb 13, 2006 2:46 pm ] |
maby try 13*6s with spacer drunms??? |
Author: | Pin4e [ Mon Feb 13, 2006 6:31 pm ] |
i've gotta have at least 12's to fit over the discs cause its 1360, and the 13's do fit under the flares so maybe i'll change them after rego? |
Author: | Mini Mad [ Mon Feb 13, 2006 8:57 pm ] |
Dean (Baracade) has his 13x7's engineered here.. |
