Engine Numbers https://www.ausmini.com/forums/viewtopic.php?f=2&t=16143 |
Page 1 of 2 |
Author: | MiniMe87 [ Mon Feb 13, 2006 3:18 pm ] |
Post subject: | Engine Numbers |
hey Being relatively new to mini's and not yhet owning one im unsure about acouple pf points, yet im looking at one on wednesday night and it is supposedly a clubman with a 1275 engine, and i know that you can tell the engine size off the engine number, but i was just wondering where on a mini's engine is that located and wat prefix's would i be looking for??? Thanks |
Author: | drmini in aust [ Mon Feb 13, 2006 3:32 pm ] |
Engine number is stamped on top of cylinder block, below #1 spark plug. All 1275s- the engine number starts with 12, except Cooper S. |
Author: | cush [ Mon Feb 13, 2006 3:39 pm ] |
drmini in aust wrote: except Cooper S.
... which start with 99h.... ![]() |
Author: | drmini in aust [ Mon Feb 13, 2006 3:41 pm ] |
cush wrote: drmini in aust wrote: except Cooper S. ... which start with 99h.... ![]() Go stand in corner...NOW! ![]() Mk1 S motor was 9F/Sa/H Mk2 S motor was 9F/XE/Y... |
Author: | cush [ Mon Feb 13, 2006 3:51 pm ] |
Ii'm afraid you're gravely mistaken, kev... 99h791 is defninatley a cooper s number.... ![]() edit actually 9F/Sa/L is the cooper (low comp) engine number? if i remember correctly |
Author: | MiniMe87 [ Mon Feb 13, 2006 3:53 pm ] |
Thanks fellow's So which is it 9 or 99????? |
Author: | czerial [ Mon Feb 13, 2006 4:01 pm ] |
9 ![]() |
Author: | drmini in aust [ Mon Feb 13, 2006 4:04 pm ] |
99H/whatever is a common UK built 998 motor, Cush. NEVER a 1275. first use of 99H here was on MiniMatic, it was 99H/119/H. |
Author: | Morris 1100 [ Mon Feb 13, 2006 5:22 pm ] |
MiniMe87, Just post the first half of the engine number and we will tell you what it is. The same with the VIN or chassis number. |
Author: | MiniMe87 [ Mon Feb 13, 2006 5:31 pm ] |
i will, but i wont no it till wednesday which is when im looking at the car, thanks for all the help!!! |
Author: | sports850 [ Mon Feb 13, 2006 6:11 pm ] |
Also have a look under the carby/exhaust manifold , if there are no bolt on plates under there then it is an 1100S motor which is actually a 1275 (most common one in vehicles here now) , also a Cooper S motor (but not an 1100S motor) should have 2 extra head studs , 1 on either side of the rocker cover , 1 near the heater tap/outlet and the other sort of near the thermostat housing . Of course if it hasn't got a cooper S head they probably won't be there either . As morris1100 said though , get the engine number prefix and post it here and we'll tell you what it is . If it starts with a 12 it should be an 1100S , if it starts with a 9 it couls be a cooperS or a 998 cc motor , post everything before the numbers at the end and we'll sort it out . |
Author: | kazjim [ Mon Feb 13, 2006 6:33 pm ] |
" if there are no bolt on plates under there then it is an 1100S motor " Hmmm, I've had 2 1100S engines now WITH the plates..... Dont trust anything from Australian BMC or Leyland.. .there was no real quality control and almost ANYTHING came out of the factory..... ![]() J |
Author: | Lillee [ Mon Feb 13, 2006 6:34 pm ] |
Cush is questioning the Master??? ![]() In this case the doc is right (like der) |
Author: | cush [ Tue Feb 14, 2006 7:52 am ] |
nah.. the doc is just wrong... 99h791 is the only cooper S engine number.... ergo... it's the best engine to have... ![]() |
Author: | Mini_mako [ Tue Feb 14, 2006 8:44 am ] |
drmini in aust wrote: cush wrote: drmini in aust wrote: except Cooper S. ... which start with 99h.... ![]() Go stand in corner...NOW! ![]() Mk1 S motor was 9F/Sa/H Mk2 S motor was 9F/XE/Y... ummmm I believe the Mk1 S motor is 9F/Sa/Y as on my engine and everywhere I've read. |
