Question re cost of cooper s disc brakes https://www.ausmini.com/forums/viewtopic.php?f=2&t=16169 |
Author: | blue_mini [ Mon Feb 13, 2006 8:35 pm ] |
Post subject: | Question re cost of cooper s disc brakes |
Hi All, how much can i expect to pay for complete Cooper S disc brake setup , with CV's , stone guards and top and bottom suspension arms etc. Tim |
Author: | min13k [ Mon Feb 13, 2006 8:48 pm ] |
second hand from around a grand up makka |
Author: | sports850 [ Tue Feb 14, 2006 6:21 am ] |
You won't need the top and bottom suspernsion arms if you are using CooperS brakes , they used normal ones . You can change your lower arms if you want to go for negative camber (bottom of wheels poking out) . Also , if you get the later Metro brakes you'll need to use negative camber lower arms to correct the difference in the camber of the metro hubs , plus their discs are bigger and need 12" wheels . CooperS disc's are by far the easiest to use as they just fit straight away . |
Author: | blue_mini [ Tue Feb 14, 2006 7:28 am ] |
Thanks - you guys answered exactley what I hoped. I have just handed over some cold hard cash (less than half what Makka advised) for a complete Cooper S disc brake setup , with CV's , stone guards and top and bottom suspension arms etc. I will reco the whole lot to make sure what goes on the car won't need replacing for a while but it sounds like i got a bargain. Tim |
Author: | Lillee [ Tue Feb 14, 2006 8:40 am ] |
I bought a set for well under a grand S/H. By the time i changed CVs, boots, new timkin tapered roller bearings, calliper kits, new pistons, new nuts, new ball joints, new brake lines, new rear cooper s cylinders and brake lines it cost me over $1400 which is only a few $100 off a brand spanking new set! ![]() ![]() |
Author: | blue_mini [ Tue Feb 14, 2006 9:36 am ] |
Quote: I bought a set for well under a grand S/H. By the time i changed CVs, boots, new timkin tapered roller bearings, calliper kits, new pistons, new nuts, new ball joints, new brake lines, new rear cooper s cylinders and brake lines it cost me over $1400 which is only a few $100 off a brand spanking new set!
Ouch, I could be in for a bit of a surprise then cost wise. ![]() its probably time to make use of some contacts to see if they can cut costs for me a bit. Tim |
Author: | kazjim [ Tue Feb 14, 2006 10:00 am ] |
But woulnt you still have needed new ball joints, new brake lines, new rear cooper s cylinders and brake lines ? J |
Author: | brickworx [ Tue Feb 14, 2006 10:04 am ] |
And a Booster? |
Author: | Lillee [ Tue Feb 14, 2006 11:16 am ] |
AFAIK a brand new cooper S brake set consists of front brake lines and a set of new ball joints. What you do need however is rear cooper s cylinders and brake lines which are extra. Forgot to mention the cost of new pads as well as new split pins, and calliper paint ![]() Other items probably not covered with the brand new brake kit perhaps is 2 new driveshaft spring clips and grease! ![]() Don't use/want a booster... |
Author: | feralsprint [ Tue Feb 14, 2006 11:50 am ] |
A few hundred dollars off a new set is still cheaper, and after you have fitted all the new bits they are the same as the new kit anyway so its a couple of hundred in your pocket. |
Author: | Lillee [ Tue Feb 14, 2006 1:44 pm ] |
Sorry for hijacking thread but... I beg to differ! I got the brakes with two left calipers. Not that big of a deal but still not a whole set. The left hub had an 850 steering arm on it and the bolts were rusted frozen hence replacement was risky/not possible. The right hub had worn bearing seats and hence the bearing could spin in the hub without bearing lock applied, even then still a worry. Drive flanges were quite second hand, brake rotors are thinnest possible (no more machining), calliper split pin holes are very second hand. For another few $100 a new set would be missing all of these gripes! ![]() ![]() |
Author: | doogie [ Tue Feb 14, 2006 3:30 pm ] |
You could just bolt them onto the car & drive it to see how they work, no point recoing something that has nothing wrong with it in the 1st place. Doogie |
