Central Oil Pickup Question! https://www.ausmini.com/forums/viewtopic.php?f=2&t=16214 |
Author: | =twista= [ Wed Feb 15, 2006 12:02 am ] |
Post subject: | Central Oil Pickup Question! |
Can someone explain for me and everyone else where the center oil pickup bolts onto, preferably post pics on where it goes on the block. |
Author: | TheMiniMan [ Wed Feb 15, 2006 12:34 am ] |
A central oil pick up is bolted to the original oil pick up spot in the gearbox,,,it is simply a smaller "sock" type strainer & pipe assy as opposed to the big "basket" type strainer as oer original These central oil pick up pipes are meant to help keep oil pressure whilst undergoing rather hard right hand cornering where the oil would normally wash over to the left hand side of the gearbox 7 away from the original oil pick up the central type pick up is placed more "central" & therfore tends to still be submerged in oil whilst any cornering is undertaken They can & do tend to get blocked up with crud more often than std pick up tho more suited to race mini applications than road, but then lots of people do fit them to road cars also, probably in the belief that it will save their engine from starving of oil around right hand corners & often without the knowledge that they do tend to block up with crud very easilly so...there you go,,,sorry no pics easy-peasy |
Author: | =twista= [ Wed Feb 15, 2006 1:03 am ] |
im finding it hard to identify where the oil pick up is on the gearbox. |
Author: | minicranks [ Wed Feb 15, 2006 6:07 am ] |
basically its what matt said but you take the entire old system out all the ipes and the basket at the bottom and replace it with a new pipe that is bent in a different way so it goes to the same place but then takes a left hand turn under the gears and lays on the bottom, so the pick up and fitment place is the same its just a longer pipe basically. |
Author: | czerial [ Wed Feb 15, 2006 10:05 am ] |
I heared the new centre oil pick ups are shite. the old ones from mini clinic used to be good. but the mini spares ones are POS |
Author: | mickmini [ Wed Feb 15, 2006 11:36 am ] |
=twista= wrote: im finding it hard to identify where the oil pick up is on the gearbox.
you can't see it from the outside. pull one apart and you will understand. |
Author: | 9YaTaH [ Wed Feb 15, 2006 12:02 pm ] |
Post subject: | Gearbox Dissassembly |
Don't forget....to be fitted when gearbox is stripped.... ![]() |
Author: | Lillee [ Wed Feb 15, 2006 12:55 pm ] |
czerial wrote: I heared the new centre oil pick ups are shite.
the old ones from mini clinic used to be good. but the mini spares ones are POS A little bird told me the "All new" design oil pickups don't work as well as the older design? No idea you didn't hear it from me... Matters not as I have an older design ![]() ![]() |
Author: | czerial [ Wed Feb 15, 2006 12:59 pm ] |
68Delux wrote: czerial wrote: I heared the new centre oil pick ups are shite. the old ones from mini clinic used to be good. but the mini spares ones are POS A little bird told me the "All new" design oil pickups don't work as well as the older design? No idea you didn't hear it from me... Matters not as I have an older design ![]() ![]() mate your not the only one that little bird talks to. I would say it is from the same person ![]() |
Author: | 1071 [ Wed Feb 15, 2006 1:37 pm ] |
I have an older one from Mspares - is that sort of half way? You really don't need to "strip" the box. Its been a couple of years since I did the last one but it only took a couple of extra hours added during an transfer gear rebuild. IMHO you really don't have to worry about clogging these days. With synthetic oil, regular maintenance etc ours cars don't really get a chance to build up a lot of gunk in the gearbox. The standard pickup screen was designed to face 100K odd miles of standard non caring abuse in an ordinary commuter. If this is you then don't worry about the central pickup. With decent tyres and suspension and the factory system you'll be amazed how often the guage shows zero pressure during "normal" cornering ...especially if you live in Roundabout Central (Canberra). Cheers, Ian |
Author: | Mick [ Wed Feb 15, 2006 2:24 pm ] |
The differences I noticed between the minispares pick up and the one from minisport was apparent ten years ago when I bought one and compared it with the other. The difference I noticed was in the making of the gauze filter on the end, the minispares one was pretty poorly made. Basically it was just crimped together with spot welds, it didn't look very professional at all. I changed mine out for a minisport one and chalked it up to experience... |
Author: | Lillee [ Wed Feb 15, 2006 2:37 pm ] |
Bugga I have one of these crimped mesh ones ![]() |
