GR Manifolds https://www.ausmini.com/forums/viewtopic.php?f=2&t=16262 |
Author: | stibinator [ Thu Feb 16, 2006 2:49 pm ] |
Post subject: | GR Manifolds |
Question... i jus got a GRE manifold for my HIF44 but there is a problem... there is no where to put a bracket to hold the accelerator cable in place? does anyone have pic of one with a bracket? or do i even need the bracket? thanks |
Author: | Simple [ Thu Feb 16, 2006 3:07 pm ] |
I have a GR manifold and the cables go through a bracket that sits between the carby and the manifold. see pic. Nothing is attached to the manifold. ![]() Cheers |
Author: | stibinator [ Thu Feb 16, 2006 5:57 pm ] |
Post subject: | . |
where would i be able to get one of these brackets? |
Author: | EST-071 [ Thu Feb 16, 2006 6:12 pm ] |
This is what you need. ![]() Can get them from www.minis.com.au or www.minisport.com.au Pete |
Author: | stibinator [ Fri Feb 24, 2006 5:39 pm ] |
ok i got one but i dont see how the accel cable will be attached to it? |
Author: | Mike_Byron [ Fri Feb 24, 2006 6:07 pm ] |
You also need a HIF style accelerator cable - I am sure others can be made to fit but the HIF one is just sooo easy. It has a nylon end piece molded into which clips onto the throttle sandwhich bracket. The HIF throttle cable is normally yellow as in the previous photo |
Author: | JAM_IT [ Fri Feb 24, 2006 6:43 pm ] |
use the standard Mini bracket, just as Simple Simon has done. Then you can use the same choke and accelerator cable. Simple really ![]() |
Author: | Christoph [ Fri Feb 24, 2006 9:43 pm ] |
how much are those GR manifolds going for these days? |
Author: | drmini in aust [ Fri Feb 24, 2006 9:52 pm ] |
Around $200 I think. ![]() |
