It is currently Fri Jul 18, 2025 5:54 pm
 Post subject: Bearings and Crankshaft
PostPosted: Mon Feb 20, 2006 3:09 pm
Some of you have come across little miss Rodney on this forum - goes by the name of Shermn or something like.
Anyway, the engine from her Mini has a worn key way in the crank. I've pulled the crankshaft out of my old engine - all but one of the areas where there were bearings (big end and main) are nice and clean, and the bearings too look good. I should be able to clean up the little bit of scratching on the one "suss" big end.
Question - should I machine the crankshaft and get oversize bearings??
See ya
Rod Image
PostPosted: Mon Feb 20, 2006 3:37 pm
You need to measure them with a micrometer, ot take to a crank grinder for quote, and they will.
They won't grind if it doesn't need it.
I get mine ground if there is more than .0005" (1/2 a thou) of taper or ovality.
PostPosted: Mon Feb 20, 2006 4:18 pm
Thanks Kev........knew I could count on you for a sensible answer. Cheers.
Umm... can the old crank be fixed or is it scrap metal??
Rod Image
PostPosted: Mon Feb 20, 2006 6:35 pm
If it's a common old Mini crank I'd simply find another as you have done.
Not worth the hassle to fix it.
If it was worth big bux like an S one, yes there are ways to reclaim it but they cost $$.
Users browsing this forum: No registered users and 118 guests
