Timing
https://www.ausmini.com/forums/viewtopic.php?f=2&t=16402
Author:  sean [ Mon Feb 20, 2006 12:37 am ]
Post subject:  Timing
how do you set the timing on a 998, it overruns after ignition key is turned off
Author:  _666_ [ Mon Feb 20, 2006 1:12 am ]
mine does too on a 1100 u need a timing light...
Author:  Keith Calver [ Mon Feb 20, 2006 5:02 am ]
This mostly happens because the ignition timing is wrong for the fuel type, causing more throttle opening at idle to make the engine idle OK. You need less throttle angle and more ignition timing at ilde to stop the problem (all other things being Ok - like spark plugs for instance). Modern unleaded fuels are crap so the manual settings are ineffective and obsolete. KC
Author:  minicranks [ Mon Feb 20, 2006 6:02 am ]
waht keith siad is true, i would also check the idle and fuel mixtures as timing is only one part of the equation and if your idle is too high or its running too rich it will also run on a fraction.
many different things can cause this but get it onto a dyno is the easiest way to getting it set up correctly, that way you will know its good.
Author:  sean [ Mon Feb 20, 2006 5:12 pm ]
how much do you reckon it costs to go on a dyno and then get it tuned
Author:  TheMiniMan [ Mon Feb 20, 2006 5:54 pm ]
Just back off the idle setting on the carbs to mae it idle lower, check your points gap is sweet & then re-time the ign at that ...& then see what happens you may even have to drop the idle setting some more after that.
