It is currently Thu Jul 24, 2025 1:22 pm
PostPosted: Tue Feb 21, 2006 6:05 am
On the way to work this morning, cruising out thru the back of kangaroo ground/eltham, there is nice down hill stretch that turns into a 90deg. right hander.
I travel this way to work everyday (and forgot about the corner :? )
Anyway, as i approached the corner (maybe about 50m away) i realised i had better slow down (was doing about 80kph)
I jumped on the brakes (twin leading edge drums) and the right rear locked up and stepped the arse out to the left, lucky there was no cars coming the other way around the corner, because i had to take the apex as i was still going a bit quicker then a should of been for that corner.
Anyway, it got the heart rate up, i had fun, i'm still alive and the mini is un-scathed.
there is no real moral here, but im just wondering why the right rear would of locked up?
Rohan
1964 MORRIS 850 - POST ZOMBIE APOCALYPSE CAFE RACER INSPIRED.
https://spotify.link/D0P4KtIP2yb
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
1.3:1 Roller tip rockers
Stupid high CR
PostPosted: Tue Feb 21, 2006 6:41 am
Downhill, weight at the front is probably part of it. could of also hit some diesel or oil etc. I'd check the other wheel cylinder, maybe the right rear locked because the left is sticking?
good you didn't hit anything though!
KB
PostPosted: Tue Feb 21, 2006 7:28 am
Cheers, Yeah lucky i didnt hit anything, there is about 40-50m of armco that goes around that stretch of road.
:P
Rohan
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
Stupid high CR
PostPosted: Tue Feb 21, 2006 8:59 am
:P
Rohan
yeah, you've seen first hand what happens when you do hit something in that situation....
PostPosted: Tue Feb 21, 2006 9:07 am
stuffed brake proportioning valve, Located under rear subframe.
PostPosted: Tue Feb 21, 2006 9:31 am
skssgn wrote:
:P
Rohan
Yes have Simon,
Lets not get into that.
It was a very sad day for all involved :( RIP lil blue
Rohan
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
Stupid high CR
PostPosted: Tue Feb 21, 2006 11:30 am
I still get flash backs from that nasty day:(
Rohan
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
Stupid high CR
PostPosted: Tue Feb 21, 2006 12:32 pm
Adjust your front and rears everytime you are under there, every week if you can be bothered...
I test my brake adjustments everytime it rains :P sometimes unintentionally :oops:
Lillee - 1969 Morris Mini K
PostPosted: Tue Feb 21, 2006 1:14 pm
Cool, i will get it checked out.
When the rear stepped out it was great, it made it easier to go around the right hand corner :P
Rohan
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
Stupid high CR
PostPosted: Tue Feb 21, 2006 4:34 pm
youve got your moral of the story right there
PostPosted: Wed Feb 22, 2006 6:02 am
No, it was that i wasnt paying attention and forgot about the corner :oops: :P
Rohan
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
Stupid high CR
