It is currently Sun Jul 20, 2025 8:55 pm
PostPosted: Mon Feb 20, 2006 9:56 pm
ok for people who rebuild there own engines what do you use to hold it while you work on it is a engine stand worth the dollars or will a bench suffice
PostPosted: Mon Feb 20, 2006 9:57 pm
i usually use a mini to hold my engine
PostPosted: Mon Feb 20, 2006 10:23 pm
Engine stand allows more access/can move it easier, but I haven't had mine on a stand, the zed's taking up the engine stand :oops:
PostPosted: Mon Feb 20, 2006 11:13 pm
Are you rebuilding an engine Marc?
I have never had an engine stand (maybe I wish I had) only used a bench.
Are you going the Suzuki route or A Series?
PostPosted: Mon Feb 20, 2006 11:15 pm
yer mine sits on the bench then on ground and now in a machinest shop :roll:
PostPosted: Tue Feb 21, 2006 6:53 am
There was a topic on this a while back. It started off about engine lifting devices from memory. The problem with most engine stands is that there isn't anywhere real convenient to mount the block and it can interefere in the assembly stage and the points to use (like Oil filter bolts) aren't real strong to support the assembled motor.
Not that I build many engines, but I use the stand for cleaning and painting the bare block, but bottom end assembly is on the bench, head assembly on the bench, then on the ground for gearbox onto block (Drmini taught me that after I struggled several times doing it the other way), head onto block etc
If you've got a good strong bench, that will suffice, but it is hard lifting an assembled block on & off the bench on your own. Good Luck.
KB
PostPosted: Tue Feb 21, 2006 7:06 am
I've got an engine stand I bought many years (probably 10 years ago now) ago from supercrap , it's supposed to be rated for a V8's weight (didn't have much faith in their lighter duty one at the time...) and find it's great . Assemble entire motor and gearbox being able to rotate motor to work from top or bottom . Whatever I can't fit in situ (flywheel/cluch etc) I do once it's back on the floor .
PostPosted: Tue Feb 21, 2006 7:43 am
sports - so where do you mount it - oil filter holes?
PostPosted: Tue Feb 21, 2006 8:48 am
Nah , I use the top engine steady hole , and a couple of rearcover mount holes , haven't had one fall yet . I can assemble everything except for the oil pump (well , I can get it in there in-situ but it's easier afterwards) and the flywheel housings and all contained in that end . It won't do a full 360 degree rotation because the crank end hits the stand but it will do about 320 degree's , more than enough to build a motor and is turned by a jack handle for easy movement and locked into one of 6 positions around the circle . See below for a better understanding of it .
PostPosted: Tue Feb 21, 2006 9:28 am
thanks guys yeah i was thinking the stand would be much easier
TK i am going the suzuki route for the mini i bought from you i have everything except the frame which hopefully i will be able to get my hands on soonish
BUT i have two other minis and one which i use for work daily and its engine is on its last legs sooooooo i thought i would when i get the time have a crack at giving it a go
just rings, bearings etc
i have a 998 which was working but blowing smoke on the floor so i will use that not looking for performance just a nice little 998 and experience inside engines
PostPosted: Tue Feb 21, 2006 11:37 am
What's the easiest way to get it off the subframe and onto the bench/ frame? Are there any lifters or such around????
2002 FORD FALCON AUIII XR6 VCT- 3984cc
Previously owned :-
1968 Morris Cooper S
1967 Morris Mini Van
1978 Leyland Minni Clubman
PostPosted: Tue Feb 21, 2006 12:01 pm
I use an engine crane and normally lift the motor out of the mini rather than drop the subframe but each to their own as to the methods . Not sure on availability now , supercrap stopped selling them as they were found to be misleading with their SWL's . Got mine from an engineering supply place , best $500 ever spent .
PostPosted: Tue Feb 21, 2006 12:03 pm
Chain lift attached to garage rafter - onto trolley same height as bench...pushy shovey, job done :)
PostPosted: Tue Feb 21, 2006 12:05 pm
repco has em now
if you have shed with a strong cross beam you can use a block and tackly set up type thing chain from the beam and ratchet it out
crane by far is the best though as you can wheel it around
PostPosted: Tue Feb 21, 2006 12:16 pm
Can you hire the cranes?? don't want to buy one......
