It is currently Mon Jul 28, 2025 2:26 am
 Post subject: Door hinges from the Uk
PostPosted: Tue Feb 21, 2006 12:07 pm
Hi all
Am off to the UK for a holiday and have found some replacement door hinges for not much money over there, mine are knackerred and new hinge pins wont be enough to save them.
Are the UK style Mk1/2 external hinges the same as the aussie ones, I have a 76 Clubby.
Rick
PostPosted: Tue Feb 21, 2006 2:48 pm
yep! :D
1971 Clubman GT - Jet Red
1980 Mini 1000 - Bold As Brass
1967 Riley Elf - Red/White
2002 MINI Cooper - BRG/White
2005 MINI Cooper - BRG/White
2022 MINI Cooper SE - BRG/White
PostPosted: Tue Feb 21, 2006 4:01 pm
Cool! Soon, no more lifting of the door to shut it. It's the little things in life........
PostPosted: Tue Feb 21, 2006 4:39 pm
You can save some room in your bags for the cross flow head you want to bring back. You only need the bushes and pins. Only cost a couple of dollars and are sooooo easy to fit.
PostPosted: Wed Feb 22, 2006 8:16 am
I've already got the bushes and pins, but the Drivers side in particular is so bad I will need to get it drilled out and oversize bushes machined up. Can be done, but the ones I have the opportunity to get are cheap as.
PostPosted: Wed Feb 22, 2006 9:32 am
Die Die Die!!
how much are they ? i have the same prob in my 74 clubman on the drivers side...
PostPosted: Wed Feb 22, 2006 12:13 pm
did you try adjusting the striker plate?
PostPosted: Wed Feb 22, 2006 1:34 pm
No, I haven't tried adjsuting the striker plate. Presumably this is a case of loosening the screws and moving it down. Won't actually fix the problem of the worn hinges but might stop it being such a pain in the meantime.
Will have a go tonight.
Rick
