Please help me identify..advice needed. https://www.ausmini.com/forums/viewtopic.php?f=2&t=16487 |
Author: | CPOCSM [ Tue Feb 21, 2006 9:31 pm ] |
I can tell you at least it is a 1275 A+ motor(the ribbing in the block) Thats about the extent of my expertise... Hooroo Rob Forsyth Miniot!! |
Author: | K-Bar [ Tue Feb 21, 2006 9:56 pm ] |
cheers for that..It certainly helps.. .so perhaps a block worth saving?? keep it coming pleeeaaaase. |
Author: | min13k [ Tue Feb 21, 2006 9:57 pm ] |
could be looks like the walls may be a little fine but if you are not going to build a higly stressed motor i think liners would be fine makka |
Author: | K-Bar [ Tue Feb 21, 2006 10:09 pm ] |
so sleeves dont bring back its strength? just help it? i guess i want to make a fast engine..but nothing too street hot.. would it survive? how much is a sleeve job roughly..anyone know? |
Author: | Flying Brick [ Wed Feb 22, 2006 7:10 am ] |
Gearbox, 22G1128 i think is a remote, all synchro box out of Mini K or Cooper S mk2. Crankshaft, on the list I have it says 12G1505(no A), EN16 1.75" con rod journal, 1275 not Cooper S, so maybe a 1100S crank. Hope that helps. (maybe the A after 12G1505 means it goes with the A+ block, not sure, someone else will know) Steve. |
Author: | Mini Mad [ Wed Feb 22, 2006 8:06 am ] |
K-Bar wrote: so sleeves dont bring back its strength? just help it?
i guess i want to make a fast engine..but nothing too street hot.. would it survive? how much is a sleeve job roughly..anyone know? I was told the you will make more power with a sleeved motor, GR puts a step at the bottom of the block for added strength..i think price was around ~$25 a sleeve, but you need to pay for two bore jobs..one to fit the sleeves and the other to match the sleeves to your piston size.. + labour |
Author: | K-Bar [ Wed Feb 22, 2006 9:03 am ] |
some good info guys...thanks very much. the sleeving sounds interesting!! ![]() im not so sure about that gear box tho. i want a rod change, so that it can go back into my clubby...the gear box i have right now would go straight under this 1275 correct?? does anyone know if that crank looks as if it has grind left in it? how can i tell? thanks for the speedy responses. |
Author: | Mini Mad [ Wed Feb 22, 2006 9:42 am ] |
why do you want a rodchange over a remote? |
Author: | K-Bar [ Wed Feb 22, 2006 9:50 am ] |
Would my 1978 clubman S be able to take a remote gear box? would my gear stick join up in the end or wat?? ![]() which is better?? remote or rod? say if i wana make faster gear changes? |
Author: | czerial [ Wed Feb 22, 2006 11:01 am ] |
i have heared that the material they use to sleeve the blocks is actually quite good and it is really no prob if you are gonna build a monster of a motor. from what i heared it will take it. Your Clubby S body will not take a remote box unless you modify where the remote housing goes up to where the gear stick pops through the floor, but in saying that i am sure it wouldnt be too hard to change this |
Author: | K-Bar [ Wed Feb 22, 2006 11:06 am ] |
yeah i didnt think it would be interchangeable. Perhaps for 300 dollars three gear boxes, an 1100, a 1275 is a good deal? think in the future i could sleeve that 1275 and go for a great engine. jus not sure bout that crank...enough meat on it? |
Author: | Mini Mad [ Wed Feb 22, 2006 11:57 am ] |
czerial wrote: i have heared that the material they use to sleeve the blocks is actually quite
good and it is really no prob if you are gonna build a monster of a motor. from what i heared it will take it. Your Clubby S body will not take a remote box unless you modify where the remote housing goes up to where the gear stick pops through the floor, but in saying that i am sure it wouldnt be too hard to change this Yes, it is a far better material than the original casting..especially on A+ blocks which tend to be more porous. A remote box is the better system. The gearchanges are quicker and more precise, and it double as an extra engine mount. Fitting one to a clubby is not hard either. A well build rodchange in fine though, i love mine. Compared to most other rodchanges though a remote is alot better. Just a matter of finding one..If you have a rodchange stick with it. |
