where to get gudgen pins https://www.ausmini.com/forums/viewtopic.php?f=2&t=16529 |
Author: | jbeenz [ Thu Feb 23, 2006 6:57 am ] |
Post subject: | where to get gudgen pins |
did i spell that wrong? you get the idea. where the hell can i buy gudgen pins? minisport uk, minispares etc dont appear to list them. not that i can find. the 1220 has taken on a new urgency, my $100 998 decided it didnt like to hold oil pressure on the way to an exam......so now im driving mums austin 1300...again. so, does anyone know where i can buy 1098 gudgens? all the machining has been done(crank ground) just need the pins and a gasket set. |
Author: | TheMiniMan [ Thu Feb 23, 2006 9:54 am ] |
Pins are matched to the pistons & come with the pistons when you buy them what`s the reason you need them seperate for? Stuffed a piston or 2 ??? You may be able to source them 2nd hand but pretty bodgey way to do things. |
Author: | jbeenz [ Wed Mar 08, 2006 8:47 am ] |
the engine came in pieces, and had been sitting, i only have two of the pins and they have rusetd,(bearing in mind the pistons are hilman imp, and in v.g.c) i have a set of worn 1100 pins which fit, but are quite worn(from another engine) the only solution i have found so far is to have the pins made, to hilman imp spec by an imp shop. |
