It is currently Wed Aug 06, 2025 8:41 am
PostPosted: Thu Feb 23, 2006 12:50 pm
how can i tell if my car has its original gear box. is there a way to tell? all the other numbers match but i dont know about the gearbox.? any help would be good.
PostPosted: Thu Feb 23, 2006 12:57 pm
Marcello
Tell us what the car is (model and year) and the number of the casting on the front of the gearbox - then we will have a go at it.
Also tell us the gear change type.
If the gearbox has been rebuilt amnd or fitted with different ratios or diffs we wont know that but tell us what you know and we will try anyway
 Post subject: gearbox
PostPosted: Thu Feb 23, 2006 9:46 pm
my car is a 1963 morris 850. it has got the correct type of gearbox (magic wand. no syncro on first) i was just wanting to know if there was a way to tell if the gearbox was the one that the car left the factory with. is there any numbers that are suppose to match with the numbers of another item, ie: engine number? or is there no way of telling? thanks for the help
PostPosted: Thu Feb 23, 2006 9:52 pm
my car is a 1963 morris 850. it has got the correct type of gearbox (magic wand. no syncro on first) i forgot to add that the gearbox has 1451 stamped on the little flat section. engine number is 8y/u/h 1439
PostPosted: Thu Feb 23, 2006 9:57 pm
Marcello - no
Individual numbers were not given to gearboxes. It was simply a generic type number and you know now that you have the right sort of period gearbox.
 Post subject: no.
PostPosted: Thu Feb 23, 2006 10:14 pm
thanks mike
