It is currently Sun Aug 03, 2025 12:18 am
PostPosted: Tue Mar 07, 2006 8:39 am
I noticed yesterday that in my mums deluxe (clubman dash cluster) that the fuel guage drops a fair way when i turn the ignition off (like all cars) but i was wondering if the tank is empty when it says that it is empty or when it get to the bottom of the gauge (like when there is no power to it)
Hopefully im not just rambling a whole bunch of crappola.
i know its a silly question and the mini fuel guages arent very accurate but i was just hoping that somebody could help me out with this!!!
Rohan
1964 MORRIS 850 - POST ZOMBIE APOCALYPSE CAFE RACER INSPIRED.
https://spotify.link/D0P4KtIP2yb
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
1.3:1 Roller tip rockers
Stupid high CR
PostPosted: Tue Mar 07, 2006 8:49 am
on my mini 25 1984, no idea wat ur guages are like
u fill the tank to the brim and its way of the scale at the top
but wen its at the start of the red line on the scale its bone dry, and wen u turn of the ignition it drops way of the scale at the bottom
PostPosted: Tue Mar 07, 2006 8:58 am
Basically they are all prone to vary a bit , I've had mini's where empty was a hair above the E mark and some that were 1/4" below the line . All you can do is carry a 4 litre mower tin of fuel in the boot and on a quiet road (not reccomended for city traffic) drive till you run out . Just be careful if you have a mechanical fuel pump though , you'll probably flatten the battery before you draw the fuel up so squirt a little into the carb to start it .
PostPosted: Tue Mar 07, 2006 9:00 am
An easy way would be find out how big your fuel tank is and as you go to fill up take note of where the fuel guage is sitting. :wink: if it's a 20ltr tank and you put in 18 ltrs then at the the point the guage was at you had 2ltrs left. So each time you fill up you get an idea of how much fuel is left in your tank fuel tanks are rarely rectangular so they don't go down in a predictable way. for example my camry does 200km before it moves off empty another 200 km to half way and another 200 km to empty. The first 200kms could be very decieving if you didn't know what it was up to :lol:
Roads need more corners
PostPosted: Tue Mar 07, 2006 9:42 am
With my LS when the guage hits the red it takes around 18/20litres to fill up.. The most I have ever put in was 23litres in one fill...
PostPosted: Tue Mar 07, 2006 10:31 am
The other day... I knew my tank was a bit empty... well I was driving to the servo and got into the turning lane (had to turn over 2 lanes) and it died. Had to push it into the servo, hehe.
I've never put more than 30litres in the tank, but on this occasion, I DID! (note it's the 1275 LS fuel tank, which is bigger like in the Rovers).
PostPosted: Tue Mar 07, 2006 10:53 am
this thing has a tank out of a Rover also, 7.5Gallons or is it 9.5 Gallons? i dunno?
Rohan
1098 +0.40
266 Kent Cam
GR Flat top pistons
HS6
Stupid high CR
PostPosted: Tue Mar 07, 2006 11:23 am
I've run out of fuel several times on the way to the servo. Thought I had enough to get there, but not quite... :(
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Tue Mar 07, 2006 12:26 pm
My previous mini's fuel gage didnt work! Well, untill one day when i ran out of feul, pushed it to the servo, filled it up........ and PRESTO, the fuel gage starts working :shock:
PostPosted: Tue Mar 07, 2006 3:01 pm
Used two of the most hi tec ways known to mini kind:
used to either tap the tank to get a rough idea of how much was left or get a bit of hose, stick it in pull it out as see how wet it got..
PostPosted: Tue Mar 07, 2006 3:05 pm
I use the hi-tech stick guage on my van.
But... hopefully standard low tech guage will work now. I've had to replace the fuel tank, and while the sender was out, I fixed it! It needed a bit of wire soldered from the terminal thing to the coil thing. It works now, well atleast it did before I put it in the tank, so who knows if it will still work when there is acutally petrol in it!
PostPosted: Tue Mar 07, 2006 3:50 pm
[quote="poeee"]from the terminal thing to the coil thing.[quote]
very technical there scott :P
speaking of fuel guages, mine works fine, but instead of an "E" for empty, it has an "O"??? what the crapola does O stand for? "Oh god get some fuel NOW!!!"??? "Over under in and out, thats what shoe-tying is all about"?? what the crap?????
78 Leyland Mini - Prince
PostPosted: Tue Mar 07, 2006 4:38 pm
I wish my van's gauge would work. It have replaced the gauge, the sender, the float, voltage reg and tried bypassing the wire from sender to gauge. Nothing worked! :x
My low tech approach is a little counter on the dash. I dial up the mileage when I fill the tank. When I reach 150miles from that counter's figure, I know I'm running on fumes and it's time to fill up.
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Tue Mar 07, 2006 5:03 pm
it already run on fumes....lol
PostPosted: Tue Mar 07, 2006 5:21 pm
OMG OMG OMG! Filled up the new tank, FUEL GUAGE WORKS, and prolly better than new!
8)
