electrical problem- she wont start https://www.ausmini.com/forums/viewtopic.php?f=2&t=16603 |
Page 1 of 2 |
Author: | matt van'74 [ Sun Feb 26, 2006 8:03 am ] |
Post subject: | electrical problem- she wont start |
so i put a charged battery in cracker this morning and turn the ignition on, i had dash lights but when i turned the key nothing at all happened ![]() i have dash lights, head lights and horn but nothing else. there is absolutely no spark and the engine doesnt try to turn over at all i guess i have pulled a wire off from somewhere but cant find it. Any Ideas? I have replaced the whole front drum set up on both sides and replaced the bolt up oil filter with a spin on one. i cant think of anything that i have done to cause this apart from dissconnecting the wire that went to the old oil filter. this is not connected to anything now any help would be great Cheers |
Author: | Shard [ Sun Feb 26, 2006 8:14 am ] |
check all the leads going into the solenoid. If that's all kosher grab a multimeter and start diagnosing where you're losing power. Shard |
Author: | matt van'74 [ Sun Feb 26, 2006 8:16 am ] |
i dont think it has a solenoid ![]() ![]() i dont have a multi meter ![]() cheers |
Author: | matt van'74 [ Sun Feb 26, 2006 8:32 am ] |
ALL FIXED A WIRE HAD SLIPPED OFF THE SOLENOID ![]() does nayone know why there is that button in the engine bay that starts your engine? i accidently bumped it and she started ![]() cheers |
Author: | sports850 [ Sun Feb 26, 2006 8:34 am ] |
Some solenoids have a button there , others have a bakelite lump that does nothing , not sure why but handy at times though I could imagine it could be lethal if someone put their hand on the wrong bit while the car was in gear ..... |
Author: | awdmoke [ Sun Feb 26, 2006 9:15 am ] |
matt van'74 wrote: ALL FIXED A WIRE HAD SLIPPED OFF THE SOLENOID
![]() does nayone know why there is that button in the engine bay that starts your engine? i accidently bumped it and she started ![]() cheers To make it easier for servicing - also makes it easier for hotwiring! Discontinued on later model cars ![]() |
Author: | eaglemini [ Sun Feb 26, 2006 11:24 am ] |
Are there any cars easier to hotwire than a mini? considering many dont have an internal bonnet release and it take 2 secs with a jump starter pack? |
Author: | Shard [ Sun Feb 26, 2006 12:21 pm ] |
Mokes are slightly easier ![]() Goodluck to anyone that ownes a moke and has an 850 steering rack that doesn't lock ![]() Shard |
Author: | matt van'74 [ Sun Feb 26, 2006 5:23 pm ] |
ive got an 850 steering rack that doesnt lock and no keys for the doors ![]() ![]() |
Author: | Rodney [ Sun Feb 26, 2006 7:16 pm ] |
I remember on a previous thread, somebody called that button the "run me over" button - hehehe ![]() Bye |
Author: | =twista= [ Sun Feb 26, 2006 10:43 pm ] |
Rodney wrote: I remember on a previous thread, somebody called that button the "run me over" button - hehehe
![]() Bye yep, left it in gear, and pressed the button outta curiosity. |
Author: | drmini in aust [ Mon Feb 27, 2006 7:59 am ] |
eaglemini wrote: Are there any cars easier to hotwire than a mini? considering many dont have an internal bonnet release and it take 2 secs with a jump starter pack?
Put a battery isolator switch in the boot... ![]() Mightn't stop them, but will slow `em down. |
Author: | =twista= [ Mon Feb 27, 2006 4:39 pm ] |
drmini in aust wrote: eaglemini wrote: Are there any cars easier to hotwire than a mini? considering many dont have an internal bonnet release and it take 2 secs with a jump starter pack? Put a battery isolator switch in the boot... ![]() Mightn't stop them, but will slow `em down. i think some people have a hard time tryin to find the battery - which slows em down. I remember some had there mini trashed cause they couldnt find the battery or something, so they poured brake fluid all over it. |
Author: | fuzzy-hair-man [ Mon Feb 27, 2006 7:47 pm ] |
An easy one that I have seen is take the dizzy cap off and remove the rotor and then put the dizzy cap back on. What's the chances they have a mini rotor in thier back pocket ![]() A little bit harder with the pulsar dizzy but still doable and a potential thief could even have a mini rotor and it still wouldn't go ![]() |
Author: | =twista= [ Mon Feb 27, 2006 8:06 pm ] |
fuzzy-hair-man wrote: An easy one that I have seen is take the dizzy cap off and remove the rotor and then put the dizzy cap back on. What's the chances they have a mini rotor in thier back pocket
![]() A little bit harder with the pulsar dizzy but still doable and a potential thief could even have a mini rotor and it still wouldn't go ![]() please explain this more? rotor? can u put it back in as easy ? |
