Details/Info Needed - WADE CAMS
https://www.ausmini.com/forums/viewtopic.php?f=2&t=16630
Author:  =twista= [ Sun Feb 26, 2006 10:14 pm ]
Post subject:  Details/Info Needed - WADE CAMS
Can anyone tell me the details for this cam? ive searched thru my reciepts and have found that the cam was purchased from Northern Mini Parts. It seems to be a WADE CAMSHAFT as the grind number was written on a wade docket, with the grind number '104'.
Much help needed as i will need to 'dial' in this cam for another block im wanting to install it to.
Thanks
Author:  Mick [ Sun Feb 26, 2006 10:38 pm ]
I won't be much help, but I remember this cam as a bit of a HOT road cam from some years ago. I had one in a Mk 1 Cooper and really liked it then.
Author:  =twista= [ Sun Feb 26, 2006 10:49 pm ]
that sounds good. i knew it was a hot cam but i dont know anything about it, like the power band or anything. i wouldnt mind knowing if someoen does, how it compares to something say like that RE-13 that docs always ranting on about.. :lol:
Author:  drmini in aust [ Mon Feb 27, 2006 6:08 am ]
It's in here somewhere if you can navigate the crap site....
http://www.wadecams.com/
I have a Tighe 104 in Barney, it's a lot tamer than an RE-13. :wink:
http://tighecams.com.au/cars.htm
Author:  bnicho [ Mon Feb 27, 2006 7:57 am ]
The wade 104 is exactly what I have in my van.
I have the specs for it somewhere if yoyu get stuck. As I recall the exhaust is the same timing as the 731 works grind, but the lift and inlet timing is different.
Nice mid-range road cam, pulls from 2,000 to 6,000 in my 1132cc with a 12G295 head. Runs out of puff at 6,000, but maybe that's because it's a 1098 crank. :)
Author:  =twista= [ Mon Feb 27, 2006 11:14 am ]
that sounds awfully familiar, 6k is high gear changing point in 3rd from experience :lol: . But im pretty sure its a wade, i checked the site - yes, its fackin sh*thouse, but i downloaded this program, to do with all their profile grinds i put in the number, it finds a close grind, then u choose the make of the motor, and then it has all the details and figures, but im not convinced. chuck those details up if u find em bnicho! 8)
Author:  =twista= [ Mon Feb 27, 2006 4:28 pm ]
how tame do you mean doc, like not as hot just mild....
Author:  bnicho [ Mon Feb 27, 2006 8:08 pm ]
Hi,
Found the faded sheet of paper hiding the in the pages of How to Modify your Mini.
Wade 104 specs:
Exhaust Timing: 65-25
Exhaust Duration: 270 degrees
Inlet Timing: 25-65
Inlet Duration: 270 degrees
Lift at Lobe .282
Hope this helps.
Author:  drmini in aust [ Mon Feb 27, 2006 8:15 pm ]
Similar on paper (270* duration) but a lot less lift (only .338" at valve advertised with stock rockers, but I measured .320").
So, I put Toyota Corolla 1.46:1 rockers in to assist.:)
<edit> Tighe 104 and Wade 104 appear to be same timing & duration, but have different lift.
Author:  =twista= [ Mon Feb 27, 2006 9:13 pm ]
ahh excellent! thanks doc, and bnicho.
