Hi Kevin,
I've been trying to nut this out as well. As you say I don't think a headlamp switch will work as it switches the circuits in a different way to what is needed.
The round bodied OZ 2 speed wiper motor (12AUW 2 speed) is a permanent magnet motor and has 12V supplied all the time. All the switching for park and the 2 speeds is done by earthing the various connections in turn via the wiper switch. The parking on these motors uses regenerative braking to stop the armature almost instantly. For this the armature is short circuited. This is the up or position 1.
The low and high (well higher than low) speeds are then selected by the other 2 switch positions. These connect the low and high speed brushes to earth in turn via the switch.
The round bodied single speed OZ wiper motor is the same but only has one set of brushes.
From what I understand the parking connections within the motor are switched via the different parts of the metal tracks on the underside of the main gear. The equivalent UK motors (14AUW?) apparently use a separate parking switch on the outside of the motor.
Non of this applies to the earlier square bodied DR3A wiper motors. These are also available in 1 or 2 speed variations. Jags are apparently a source for 2 speed versions.
For those hoping to find a wiring diagram in the OZ workshop manual (TP832 1971) the only one I have found that is correct for the single speed OZ wiper motor as fitted to late MK1.5 'S' and Mini Deluxe cars, and has the correct wire colours, is for the Mini saloon and van (Late models) on page n-24. I guess this makes sense.
The MK2 'S' and Mini K use the same connections but use different coloured wires as shown on page n-20.
If you have a late MK2 'S' (lift up door handles) then no luck here. Just guessing but I suspect the wiring colours would be the same as Clubman cars fitted with the 2 speed motor but the switch would be the Lucas toggle sw No 35927 as fited to MGB cars as mentioned by Kevin.
So to fit the 2 speed OZ wiper motor you need the 35927 switch and run an extra wire between the motor and the sw for the high speed.
Thomen
Don't know if this helps your flat battery problem but it seems as though you may have wired it up wrong or your not using the correct switch. You don't need the earth at the motor as all the connections to earth are made via the switch.
There is another earth wire at the motor but it is connected between the motor body and earth but it is nothing to do with the switching for park and the 2 speeds. The motor is rubber mounted to the body and this wire earths the motor body to the car body. Not sure why, maybe for radio interference?
Edit: I think you can use a double pole triple throw toggle switch in place of the Lucas 35927 sw but you have to jumper all the connections on one side together or use individual earths for each position. The 35927 sw is a double pole triple throw switch but the connections on one side are jumpered internally so you only need one earth connection.
Removed reference to earth in park position.
Hope this helps
RonR
