It is currently Thu Jul 17, 2025 2:01 am
 Post subject: Head Nuts Re-tensioning
PostPosted: Sat Feb 25, 2006 8:30 pm
G'day,
Dylan has a re-co'ed engine in his Mini. When it was built, it sat in the garage for about 6 months, and has never had the head re-tensioned.
Since fitting the engine, (about 4 weeks ago) he's driven maybe 1000 Km's and its all ok.
Should I re-tension the head or leave it alone????
Thanks
Rod Image
PostPosted: Sat Feb 25, 2006 8:36 pm
Re-Tension For Sure.
Gasket will compress a bitmore, things will settle, need to re-tension to b safe.
No more Minis!......For now.
PostPosted: Sat Feb 25, 2006 10:55 pm
they are tensioned to 50 foot pound just incase you didnt know :wink:
PostPosted: Sat Feb 25, 2006 11:01 pm
Yepp - retension and enjoy.
Dad was an engineer before driving trucks and he always believed in the click and nip method(well for diesels anyways). Click to the torque and nip a flat. 500km later nip another flat and all was sweet. Bush mechanics - maybe but the man never broke down.
I am in the sameboat with a complete motor sitting on the bench(found a hornet making a nest in my thermostat housing!!!) so will run the motor and nip up after the first run(whenever the hell that may be!!!)
Hooroo
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
PostPosted: Sat Feb 25, 2006 11:03 pm
and back 'em off a bit before re-tensioning (for the uninitiated) :)
PostPosted: Sat Feb 25, 2006 11:10 pm
Good point AWD - hows Safety Bay tonight?
Hooroo
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
PostPosted: Sat Feb 25, 2006 11:24 pm
Thanks everyone :wink:
Rod Image
PostPosted: Sun Feb 26, 2006 1:40 am
Hooroo
Rob Forsyth
Miniot!!
Warm & windy (cause it's summer) :)
PostPosted: Sun Feb 26, 2006 1:44 am
Can't speak for Safety Bay, but Port Kennedy is warm and cosy with clear blue skies.
Everything is perfect in the west! 8)
PostPosted: Sun Feb 26, 2006 1:54 am
bloody hot and no wind even at 3 in the morning in sydney
PostPosted: Mon Feb 27, 2006 2:51 pm
well i tighened down the head but didnt get a chance to adjust the valve rocker clearance while i was at it, so that a job for when im at mum and dads next (i dont think i ahve the right tools). tell me please, is this normal? i tightened them down to 42lb/sq. in in the following sequence (looking down at the head, thse are the studs)
6 2 4 8
7 3 1 5 9
numbers 1, 2, 4, 6 and 8 were fine, but 7, 3, 5 and 9 took about a fifth of a turn before the torque wrench clicked. this is ok???
oh and i had to put my front number plate back on too... grrrr
78 Leyland Mini - Prince
