Wiper motor.. https://www.ausmini.com/forums/viewtopic.php?f=2&t=16744 |
Page 1 of 2 |
Author: | thomen [ Wed Mar 01, 2006 4:07 pm ] |
Post subject: | Wiper motor.. |
Hi All, finally got my van today!!!! alas the wipers are verrry tempramental! after alot of help from steve and calm advice i hosed the thing with wd40 as it hadn't been run that often which helped for a little while my wipers will get to about halfway and stop until i nudge them and then start again... most of the time they won't even budge... i checked the earth connection and the wiring from the switch to the motor but i dunno! any advice? |
Author: | h0nk [ Wed Mar 01, 2006 4:12 pm ] |
I had a similar problem.. The wiper cable that comes out the top of the motor wasn't screwed all the way in.. might help to check that? |
Author: | fuzzy-hair-man [ Wed Mar 01, 2006 4:14 pm ] |
Try pulling apart wiper box it's self. Mine was full of some rather solid grease and muck and worked better once I had cleaned it up and re greased it ![]() |
Author: | chopchop [ Wed Mar 01, 2006 4:20 pm ] |
Thomen bringing it for fish n chips tomorrow night? ![]() |
Author: | thomen [ Wed Mar 01, 2006 4:24 pm ] |
i will if i can find a new wiper motor!!! or one that works!!!! |
Author: | 13secmini [ Wed Mar 01, 2006 4:31 pm ] |
i got a 2 speed wiper motor here you could of picked up when you came over last week, bugger, if you have no luck let me know and ill hold it for you. |
Author: | Steve [ Wed Mar 01, 2006 4:32 pm ] |
honk drove his without wipers in the rain on many occasions. Come to fish and chips good luck. |
Author: | thomen [ Wed Mar 01, 2006 4:33 pm ] |
i think my current is a single speed would there be any mods in wiring it up?? how much would you want for it? are you free tonight sometime? |
Author: | adeee [ Wed Mar 01, 2006 4:50 pm ] |
poeee has problems getting his wipers to stop. Sometimes they even start when we dont want tehm to! Blame the gremlins. |
Author: | thomen [ Wed Mar 01, 2006 5:57 pm ] |
hahah love the gremlins! nearly as much as i love steve and mikey! you guys are awesome! im so going to start the ausmini steve and mikey fan club!!! |
Author: | h0nk [ Wed Mar 01, 2006 6:01 pm ] |
Steve wrote: honk drove his without wipers in the rain on many occasions.
Haha yep sure did ![]() ![]() |
Author: | simon k [ Wed Mar 01, 2006 6:11 pm ] |
the wipers on my 850 van used to do that... they'd get half way across the screen and stall like it was too much effort to go the rest of the way - if I gave them a push they'd keep going.... When they did it half way to melbourne, I took the left hand one off and the right one worked fine after that... I need a 2 speed wiper motor - if you don't get Brad's, can I buy it? |
Author: | JC [ Wed Mar 01, 2006 6:36 pm ] |
Is one able to fit a two speed wiper to an 850? |
Author: | thomen [ Thu Mar 02, 2006 12:54 am ] |
on closer inspection the one in my van is a 2 speed just wired to run at fastest speed... as for brads im going to pick it up tommorrow! then into my dash lining 3 bolts (as steve said!) and go from there! what sort of glue do people usually use for gluing linings to the body? as the backing behind my speedo is glued to the sides of the shell and ill need to remove and replace glue! thanks, - tom |
Author: | simon k [ Thu Mar 02, 2006 7:06 am ] |
thomen wrote: on closer inspection the one in my van is a 2 speed just wired to run at fastest speed... as for brads im going to pick it up tommorrow!
then into my dash lining 3 bolts (as steve said!) and go from there! what sort of glue do people usually use for gluing linings to the body? as the backing behind my speedo is glued to the sides of the shell and ill need to remove and replace glue! thanks, - tom kiwkgrip - it's the same sort of yukky yellow glue can I have your old motor then? I'll fix it ![]() |
