Steering rack leak https://www.ausmini.com/forums/viewtopic.php?f=2&t=16817 |
Author: | WhoDat [ Fri Mar 03, 2006 6:49 pm ] |
Post subject: | Steering rack leak |
Who can explain to me what is going on here? ![]() There is a small leak on the ground that looks like oil. What fluid is this? How serious is it? Can I just replace the boot or is it a rack out job? Any advice appreciated Dat |
Author: | 9YaTaH [ Fri Mar 03, 2006 8:09 pm ] |
Post subject: | Wally |
Yep...wally gaiter is cactus....you need to search on steering racks and work out what to do....some use oil...the Doc packs em with grease. Buy a new gaiter or two and maybe some tie rods ends if they need doing....undo the tie rod and slip the old gaiter/boot off...helps to have that side jacked high ![]() ![]() Oh...much more driving is not recommended until fixed....you risk crap ruining the nice clean interior of your rack or worse running dry and stuffing the rack. |
Author: | drmini in aust [ Fri Mar 03, 2006 9:45 pm ] |
Mini places like Karcraft sell new rack boots as a pair, they are pretty cheap. Undo the tie rod end, and the boot clips. remove boot, fit new one and tighten only the big clip. Then stick a pump action oilcan nozzle inside boot next to the tierod, and pump some oilz in there. I use 90/140EP or whatever heavy gear oil I can get. Move rack from lock to lock, if you have put too much oil in it will squirt the excess out. Then refit the small clamp. I have done this on my 1970 original rack a few times over the years, it has now done ~140,000 miles and is still not loose. ![]() Modern rack grease can be used in Mini racks, but best to do that on assembly. If it's an old oil filled rack I'd just top up with oil. |
Author: | WhoDat [ Fri Mar 03, 2006 10:09 pm ] |
Thanks guys - it sounds like this one is not too bad then. After being off the road for 3 months with a blown engine this is the last thing I needed. I was dreading having to pull the rack out. But just replace the rubber boots and fill up with some oil sounds do-able. |
Author: | cush [ Fri Mar 03, 2006 11:57 pm ] |
then get a wheel alignment.. ![]() or remember howmany turns you needed to undo the nut.. ![]() |
