Doors https://www.ausmini.com/forums/viewtopic.php?f=2&t=1683 |
Page 1 of 2 |
Author: | willy [ Thu Aug 26, 2004 9:03 pm ] |
Post subject: | Doors |
Couldnt be assed to find the original post but. Why do the doors need to be open when the car is jacked up ![]() ![]() |
Author: | adsmini [ Thu Aug 26, 2004 9:23 pm ] |
UM do they!!! ok whoops!!! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Author: | J_A_M [ Thu Aug 26, 2004 9:26 pm ] |
"c'mon, c'mon, c'mon now touch me baby...." oh sorry, wrong Doors..... ![]() |
Author: | Anto [ Thu Aug 26, 2004 9:30 pm ] |
I would assume you mean using an original jack - the reason you open the door is otherwise the jack scratches all the paint off! At least I think that is the reason, looking at the design of the original jack. Heard of a poor bloke doing it to his recently restored MGB ![]() |
Author: | willy [ Thu Aug 26, 2004 9:46 pm ] |
Aw fiddle sticks. Yeah makes sense now. Heart goes out to the MGB owner. Doors ![]() |
Author: | J_A_M [ Thu Aug 26, 2004 9:50 pm ] |
Author: | drmini in aust [ Thu Aug 26, 2004 10:10 pm ] |
Post subject: | Re: Doors |
wgormly wrote: Couldnt be assed to find the original post but.
Why do the doors need to be open when the car is jacked up ![]() ![]() It's in this post.. http://ausmini.tziworld.com/viewtopic.p ... sc&start=0 If doors aren't open, you can't swing the wheelbrace around to wind ze jack... Also the jack should be set with the foot in a bit, so it swings to nearly vertical when wound right up. ![]() |
Author: | supercharged 850 [ Fri Aug 27, 2004 1:05 am ] |
god damn, dont waste your time - go out and buy a REAL jack and throw that piece of crap jack in the bin!!! I'm trying to work out how to make a Formula One style jack for my cars.... no pumping OR winding, just push down on the handle ONCE.... |
Author: | Mike [ Fri Aug 27, 2004 1:55 am ] |
Yea JAM "what was that promise that you made, why wont you tell me what you said?" |
Author: | drmini in aust [ Fri Aug 27, 2004 5:03 am ] |
supercharged 850 wrote: god damn, dont waste your time - go out and buy a REAL jack and throw that piece of crap jack in the bin!!!
I'm trying to work out how to make a Formula One style jack for my cars.... no pumping OR winding, just push down on the handle ONCE.... If you just got a flat out in the boondocks and need to fit the spare, at least the stock jack will go in there and lift it up off the deck, regardless of how low the car is. For home use though, any jack will beat it. ![]() |
Author: | J_A_M [ Fri Aug 27, 2004 8:37 am ] |
Mike wrote: Yea JAM "what was that promise that you made, why wont you tell me what you said?"
Nooooooooooooooooooooooooo!!!!!!!!!! I just got it out of my head........I couldn't sleep with the damn Doors playing in my head....... |
Author: | Lillee [ Fri Aug 27, 2004 9:44 am ] |
Yeah trolley jacks and fancy $1000 jacks don't mean crap if it can't fit under the car! my front was low befre, but now it is so low I can't fit anything under there. I need to jack it up from the front steady rod thingy with a normal jack first before being able to put the trolley jack under. I don't fancy carrying the 10kg trolley jack around everywhere so any jack will do in case of a flat, even a crappy 36yr old one ![]() |
Author: | Anto [ Fri Aug 27, 2004 10:27 am ] |
Boondocks? You mean Queanbeyan, right? ![]() 68Delux - I always have that problem with my hydro. But remember, it's a hydro! If you lift the car up yourself first, it doesn't settle as low to the ground and you can fit the jack under. When I do an oil change, I jack the front of the car up then let it down, only then will my oil tray fit under the sump! |
Author: | Lillee [ Fri Aug 27, 2004 11:15 am ] |
Nope tried that, still too low! ![]() |
Author: | bnicho [ Fri Aug 27, 2004 12:10 pm ] |
Mini vans have a kind of scissor type jack from the factory. The hole for a sedan post-type jack (in the sills) is blocked off on a van. Incidentally the Mini van jack is the SAME as a Jag E-TYPE! Classy! ![]() Go to the wreckers and get a cheap scissor jack from any old car. Weld a plate on the top to spread the load a bit if needed. But only use it on the subframes, never on the floor! Most scissor jacks will wind down to 2" flat. If you Mini is too low to fit one of these under it, you have problems.... ![]() |
