Hard decison, need help to choose
https://www.ausmini.com/forums/viewtopic.php?f=2&t=16834
Author:  Beefa [ Sat Mar 04, 2006 3:20 pm ]
Post subject:  Hard decison, need help to choose
Hello all,
Well we had Beefa up on the hoist to do the CV's and we noticed that there is more rust then we first thought. Behind the front bumper there is a little on both sides, as well as the usual floor pans which I already knew about.
With the rust in the body, is it easier and cheaper to buy another Clubby body and transplant everything, or just fix the rust that we have found?
I don't really want to sell him, I've grown atteched to him finally :oops:
The engine also seems to have some bad oil leaks, even though I have fixed all the ones we found before. Is new oil leaks a sign of a sad engine? Wil it be cheaper to keep fixing the oil leaks or buy a new engine altogether?
Thanks guys :roll:
Lynda
Author:  Braveheartjunky [ Sat Mar 04, 2006 3:25 pm ]
Fix the rust. You at least know the car and you might buy a car that has more problem's than you think.
Author:  boho [ Sat Mar 04, 2006 3:31 pm ]
Can't you get spare floor panels from http://www.minispares.com? If they have it, Northern Mini Parts and others in Aus will have access to it... :)
Author:  Hagar [ Sat Mar 04, 2006 3:47 pm ]
Should be easier to fix the leaks. They're not necessarilly a sign of anything other than a failed gasket/oil seal. Making sure the crankcase breathers are present and correct might reduce them or slow any re-occourance.
Failing that, keep the oil topped up, ignore the leaks, put down a drip tray where you park at home, and sleep well (better) in the knowledge the the leaking oil is protecting the body where it sticks! :)
Author:  sports850 [ Sat Mar 04, 2006 4:04 pm ]
FIx whatever rust you find , then you know beefa's body's good , if you buy another one you may find the new body's just as bad or worse , plus it's a fair bit of work to transfer everything .... As for the oil leaks , just fix them as you find them , just a sign of age and/or wear . Also , just as a check , tighten all the little bolts that join the gearbox to the motor , had a mini at one time that had rattled a few loose and oil was seeping out all the way around , lot of oil leaks with a simple solution . Hopefully beefa's will be too .
Author:  Besser [ Sat Mar 04, 2006 4:28 pm ]
Post subject:  horses for courses
If you have the time and facilities then go a rebody if not patch as you go...
Author:  Beefa [ Sat Mar 04, 2006 6:23 pm ]
OK well the rust repair panels for the floor hopefully wont be too expensive.
What about the rust that we found behind the bumper bar in front of they tyre, can I buy repair panels or anything like that? Or do I just chop it out and hope for the best?
The oil leaks have been an ongoing problem for the past year and a half I have had the car. Every time a new one starts I fix it, then not long after another one starts....its a never ending thing.
How much is a new 1100? I've been seriously thinking of putting a new engine in him for a while...the engine leaks found today have just confimed I will be :x
Author:  cush [ Sat Mar 04, 2006 7:35 pm ]
*error...signature input buffer exceeded*
:shock:
Author:  willy [ Sat Mar 04, 2006 7:51 pm ]
In Laymans terms; CHANGE YOUR **** SIGNATURE, ITS WAY TOO **** BIG.
GAAAAAAAAAAAAAAAAAAAAAAAAAAAAAH
Author:  Beefa [ Sat Mar 04, 2006 7:57 pm ]
How does F*CK YOU willy sound? Damn good to me....so F*CK OFF willy.
I asked for ideas and help not your smart ass comments :evil:
Author:  willy [ Sat Mar 04, 2006 8:03 pm ]
BAAAAAAAAAAAAAAAAAAAAAAAAAHAHAHA
sorry Lynda. :roll:
Author:  Beefa [ Sat Mar 04, 2006 8:09 pm ]
Apology accepted willy....
Now can anyone help me with the rust problem in the bumpers?
Author:  Stuwey [ Sat Mar 04, 2006 8:17 pm ]
Sounds just fine to me - I cant see anything wrong with that one :lol:
Rust is a bitch. You can chase it, and you can whip out the grinder, some fresh metal, and the MIG welder, and do the few patches you need, but remember...
RUST NEVER SLEEPS.
With my daily driver, i'm just trying to igore the rust. She goes fine, doesn't even leak oil, and is comfy and quiet. Rust is too bloody expensive to fix. Turn a blind eye and you'll soon find ignorance is bliss.
