Weird tapping sound? https://www.ausmini.com/forums/viewtopic.php?f=2&t=16920 |
Author: | EST-071 [ Tue Mar 07, 2006 7:24 am ] |
Post subject: | Weird tapping sound? |
I have a problem which has me stumped ![]() I have had the front hubs pulled apart twice now and still can not find a cause, I am now thinking it could be the inner pot joint or diff. Sorry for the long post but any help would be great. Pete |
Author: | GAT51 [ Tue Mar 07, 2006 8:06 am ] |
Had similar problem a few years ago. Turned out to be a tooth in the diff that had chipped. Eventually the crown wheel picked up the chip and broke off two teeth. Result new crown wheel and pinion and engine out. |
Author: | CRU17Y [ Tue Mar 07, 2006 8:19 am ] |
I think i am having the same issue but mine appears to be happening on the passengers side front. ohh damn it. this is becoming costly. |
Author: | EST-071 [ Tue Mar 07, 2006 9:50 am ] |
GAT51 wrote: Had similar problem a few years ago. Turned out to be a tooth in the diff that had chipped. Eventually the crown wheel picked up the chip and broke off two teeth. Result new crown wheel and pinion and engine out.
I hope this is not it. ![]() Pete |
Author: | CRU17Y [ Tue Mar 07, 2006 10:21 am ] |
deluxe_68 wrote: I hope this is not it.
![]() Pete I hear you buddy |
Author: | EST-071 [ Tue Mar 07, 2006 4:22 pm ] |
If it was this, would I be able to tell without pulling it apart? Also wouldn't it make the sound at all speeds not just over 80km/h? Pete |
Author: | EST-071 [ Wed Mar 08, 2006 7:14 am ] |
Any body got any ideas? Pete |
Author: | Maxi23 [ Wed Mar 08, 2006 7:24 am ] |
Check your uni joints. I had a tapping when a U-Bolt nut came lose and the metal started hitting the the gearbox casing....it wore away a nice groove into my gearbox casing. |
Author: | EST-071 [ Wed Mar 08, 2006 10:01 am ] |
I have got pot joints not uni joints. Pete |
Author: | GAT51 [ Wed Mar 08, 2006 11:55 am ] |
If it was this, would I be able to tell without pulling it apart? Also wouldn't it make the sound at all speeds not just over 80km/h? Pete Mine cut in and out around 50K, no idea why - but possibly to do with the weight on the gear. Try backing off and then applying the power again. When I did this the noise went away for an instant. I only identified the problem when it all went bang!! |
Author: | EST-071 [ Wed Mar 08, 2006 6:09 pm ] |
I think I isolated the noise, swapped both front wheels over and the noise followed. So it is either the tyre or the rim. At a quick glance they both look fine but will wait and clean the rim up and have a ggod look at it. Cheers Pete |
Author: | Morris 1100 [ Wed Mar 08, 2006 6:22 pm ] |
Did you check the tread for a nail or a stone? Are the tyres old? If a tread is starting to lift it will make a noise when you go faster. Check for cracks and splits and bumps. |
Author: | EST-071 [ Wed Mar 08, 2006 7:05 pm ] |
Yeh looked for a stone or nail but none there, the tyres are about 4 years old and it does look a bit funny in one spot, like it has been really hot. Pete |
