It is currently Sat Aug 02, 2025 5:07 pm
 Post subject: Surging problem
PostPosted: Thu Feb 23, 2006 10:55 pm
Howdy all, I Have a problem with my mini. It's a 1275 with twin SU's. The problem is that when the car is being driven it surges as soon as it gets over about 2500rpm. It sounds and feels like the car is in the wrong gear. I have re-tuned the carbs and that didn't seem to do anything. The engine revs fine when not in gear. Any help is much appreciated.
PostPosted: Thu Feb 23, 2006 11:00 pm
ok,,,may be a problem with your distributor vac advance mech
have you got vac advance type dizzy fitted???
often the dizzy base plate wears & wobbles around like a dik in a shirt sleave & as the vac advance works it will wobble/cock the plate & open the points up more, then because the timing change occurs as the points open the vac drops & closes the points, but as the points close again the vac increases again, so the pull on the plate opens the points again, & so on & so on, surge surge surge.
catch 22 type thing...try disconnecting the vac advance (if you have one) & drive him magain & see if it still happens
cheers & let us know what you find
 Post subject: surge
PostPosted: Fri Feb 24, 2006 12:42 am
Cheers mate, I do have a vac advance dizzy, I will give disconnect it and give it a go tomorrow and then post again tomorrow night. Hopefully that will solve the problem. Thanks again
PostPosted: Fri Feb 24, 2006 10:30 pm
disconnected the vac advance lead from the dizzy, went to start it up... Now it wont start! I put the lead back on and tried again, still nothing. The exhaust is totally screwed, it leaks from the lcb where the two pipes go into the 'y' piece, would this be the reason it wont start or is it something ignition related?
Howard: "You don't need a pen to be a writer Vince"
Vince: "I think you do"
PostPosted: Sat Feb 25, 2006 12:18 am
HAHAHA Dixon Bainbridge! I love The Mighty Boosh!! That was the funniest show out! Pity it's not on any more. Sorry bout the OT post.
PostPosted: Sat Feb 25, 2006 3:11 am
No worries chief, any comment of The Mighty Boosh is most welcome.
PostPosted: Sat Feb 25, 2006 7:16 am
You guys and girls (incl myself...lol)live in a time warp. Love the image Dix ...what a hoot.
With the question at hand, do as Matt says.
The leak may be contributing to the no starting but there is something else there me thinks.
If it is surging also(and this is a long shot tooo), might be the clutch letting go when the revs get to 2500rpm??? I say this as I was on my way to a Kangaroos match last year and the car was slipping at 2000rpm...was the original clutch giving up the ghost(mind you it had 180-odd thousand kays on it)
Not doom and gloom and it is almost always a very simple thing99 percent of the time. Start with pulling all the plugs and cleaning them off with a wire brush(if there is a leak they could be heavily carbonised). Clean the dizzy contacts while you are doing the internals as well as the rotor button(incidently, that is my immobiliser now...pull the dizzy rotor...lmao!!)
Good luck at getting that Y-piece off too - that is my most hated job!!!
Hooroo
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
PostPosted: Sat Feb 25, 2006 11:34 am
thanks for that, i did take all the plugs out and they were all black with soot, does this mean it was running too rich? I'll give the distributor a once over too.
PostPosted: Sat Feb 25, 2006 12:05 pm
Maybe - but could be a combination of all things combined. The leaky flange will have contributed to it and if the soot gets too thick - it stops sparking. A quick clean with a brush should get you going again. With the SU - turn the jet nut UP!!! 3 flats, drive and check - if no longer black - wind down 1 and drive and check, so on and so on.
Get the exhaust fixed though - cant have you crashing the mini from CO asphyxia...
Hooroo
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
PostPosted: Sat Feb 25, 2006 2:04 pm
lol, its good to know that someone cares. I have changed the mixture on the carbs so it should not be rich anymore.
PostPosted: Sat Feb 25, 2006 6:11 pm
How dirty is the air cleaner & also make sure your choke isn`t stuck on
PostPosted: Sat Feb 25, 2006 9:57 pm
My baby finally starts and goes!!! 4 new spark plugs did the job. Runs quite smoothly now. Thanks for all the advice.
PostPosted: Sat Feb 25, 2006 10:17 pm
Excellent o masked one. Did you sort out the sooting at all? I had similar issues when I ran SU's and took me weeks to nut it out...lol
Perseverance is noble...
Hooroo
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
PostPosted: Sat Feb 25, 2006 11:03 pm
Ahh thats not a mask mate, thats really what my face looks like.
Anyway... I have reset the mixture settings on the carbs and did the piston test thingo and the engine revved up and dropped down to idle, so all is well.
PostPosted: Sat Feb 25, 2006 11:06 pm
Dixon sorry about this OT post aswell.. But I've just obtained the second season of The Mighty Boosh!! :lol: :lol: The first episode is funny! Can't wait to see the rest. You seen the second yet?
