It is currently Thu Aug 07, 2025 6:32 pm
 Post subject: Too much oil
PostPosted: Wed Mar 08, 2006 10:05 am
I topped my oil up at the weekend and looks like I have put too much in, it is quite a way over the maximum on the dipstick. Looking at the block I think I can see oil coming out of the Oil Pressure Relief Valve, which I guess is part of it's purpose.
Like all Mini's it drops oil anyway, should I just leave it until it drops enough to get back to normal levels or should I drain some off?
Rick
PostPosted: Wed Mar 08, 2006 10:21 am
you can frig up your motor with too much oil.
Drain it to the right level!
Website: www.justanothermini.com
 Post subject: Re: Too much oil
PostPosted: Wed Mar 08, 2006 10:31 am
No, that's not how it works!
Too much oil will lead to blown seals. Drop some of that oil out the sump plug ASAP!
PostPosted: Wed Mar 08, 2006 4:33 pm
Drain some out before you stuff things up big time - very expensive to fix when the job will only take you 5 minutes.
Rod Image
PostPosted: Wed Mar 08, 2006 4:35 pm
Hmm...how much oil is too much ?
My oil pressure used to drop to about 10 going around sharp corners, so i was told to fill it up about 1cm past the full line on the dipstick.
Should I not do this in future ?
No more Minis!......For now.
PostPosted: Wed Mar 08, 2006 4:49 pm
Max, i used to do the same before i got a centre oil pickup whenever i went on spirited drives..Never had a problem.
We really need to determine how much higher it is than max on the dipstick a cm or two shouldn't cause any problems
PostPosted: Wed Mar 08, 2006 5:41 pm
on the topics of oils what do you guys use and what is the recommended oils to use. :shock:
PostPosted: Wed Mar 08, 2006 6:05 pm
IMO you can't go past Castrol Formula R 20w50 NON SYNTHETIC..
It's the same as the new Castrol EDGE Sport 25w50
http://www.castroledge.com.au/
Good stuff indeed...
PostPosted: Wed Mar 08, 2006 6:07 pm
Yup, I use castrol Formula R, never had an issue with it. Kazjim put me on to it.
Also, are the centre pickups hard to fit ?
PostPosted: Wed Mar 08, 2006 6:10 pm
Not really, they just replace the old strainer with a sock like filter and extended tube, much easier to fit with the engine out and apart ;) No cheap for what they are, but i'd do it while it's apart.
