nut on clutch housing https://www.ausmini.com/forums/viewtopic.php?f=2&t=1697 |
Author: | 68matic [ Sat Aug 28, 2004 2:40 pm ] |
Post subject: | nut on clutch housing |
the nut and cap that are on a threaded thing on the left of the engine, clutch housing i believe, are a little loose. the whole assembly (nut, cap, thread) are tight together, but all can move about 20 degrees is this a problem thanks the engines a 1100 clubman |
Author: | drmini in aust [ Sat Aug 28, 2004 2:43 pm ] |
That is NORMAL. The plunger has some rotational clearance on the clutch lever arm's ball. ![]() |
Author: | 68matic [ Sat Aug 28, 2004 3:09 pm ] |
thanks Doc youre a champ |
