It is currently Tue Jul 29, 2025 7:12 am
 Post subject: Question abouts brakes
PostPosted: Thu Mar 09, 2006 6:15 pm
could i put a t peice as shown in the picture to convert my tandem cylinder to single, and also what is the thing that both pipes run into
77 Leyland Clubman
1293cc, LCB extractors, pulsar dizzy (recurved), cooper s disc brakes, 40DCOE Weber
PostPosted: Thu Mar 09, 2006 6:37 pm
No.
the top pipe is the fluid going to the brakes the bottom is the return.
The thing the pipes run into is the divider (forgotten its proper name) that sends the flud to the front and back of the car.
PostPosted: Thu Mar 09, 2006 6:44 pm
I would've thought the rust hole in the firewall as more of an issue :shock:
PostPosted: Thu Mar 09, 2006 7:00 pm
Aye, but as the car has been resprayed I recon he has sorted that!
PostPosted: Thu Mar 09, 2006 7:22 pm
yea the rust is gone, but does someone know an easy way to get back to single circuit brake setup
77 Leyland Clubman
PostPosted: Thu Mar 09, 2006 7:27 pm
Why do you want to change them?
PostPosted: Thu Mar 09, 2006 8:03 pm
Just a warning that by removing the twin cylinder you are making the car ilegal as it is one of the ADRs the car must meet :D
PostPosted: Thu Mar 09, 2006 8:40 pm
Keep the tandem cylinder. If you want to add a servo? just plumb it into the front circuit.
BTW repair kits for that tandem MC are still available, from Repco or brake shops.
`PBR? p/no is K7800X. :wink:
PostPosted: Fri Mar 10, 2006 7:44 am
the reason i need to change from a tandem to single is the clutch master cylinder with the plastic tank found on early clubbies does not fit, it hits the pipes comming out of the tandem brake cylinder, and both my clutch and single circuit brake master cylinders are brand new. so if i want to keen the tandem i have to go out and buy a clutch master cylinder like the tin type
drmini in aust
can you explain what you mean by add a servo
77 Leyland Clubman
PostPosted: Fri Mar 10, 2006 8:07 am
The dual circuit one should fit with the normal plastic tank clubbie clutch master cylinder , turn the clutch cylinder round 180 degres so the tank is at the back , they were made to be able to fit either way .
Doc is talking about if you were changing the master cylinder to be able to fit a brake booster/servo assist . SOme mini's used a VH44 vacuum powered brake booster that used the vacuum of the motor via a pipe off the manifold to make it easier to push the brake pedal . They didn't increase your braking power , just made it easier to push the pedal . These are easier to fit to a single system and the most common reason for people to switch from a dual to a single system .
PostPosted: Fri Mar 10, 2006 2:29 pm
i assume when your fitting your new cylinders you will also be replacing the solid lines? if so they do bend quite a bit and should be able to clear the interference
Users browsing this forum: No registered users and 72 guests
