It is currently Sat Jul 19, 2025 6:16 am
 Post subject: Sunroof Position
PostPosted: Sun Apr 09, 2006 8:42 am
I will be cutting hole to install sunroof in the mini I am doing up this week. Wondering how far from the front lip I should start marking the template? Anyone got pics of there own I could look at?
Thanks, steve :D
PostPosted: Sun Apr 09, 2006 9:33 am
Resident Haemorrhoid
i recently put one in see here
http://www.ausmini.com/forums/viewtopic ... +completed
it has before during and after pics shpould give you some idea basicly i set it up so i only had to remove 1 lining cross brace the other is about 45 mm from the back of the sunroof
Gadget
mtsmini wrote:
Tombo wrote:
PostPosted: Sun Apr 09, 2006 9:40 am
Tip i used an electric jigsaw with a metal cutting blade and i cut the blade down so it didnt cut throught teh lining i then used a knife to cut the lining out after teh hole was cut so i had enough lining to fit nicley in to teh sunroof trim :wink:
mtsmini wrote:
Tombo wrote:
PostPosted: Sun Apr 09, 2006 1:31 pm
Thanyou gadget. Pics have been a great help. Have already removed that bar. Sunroof arrives monday. Sheel is currently striped and sanded so shouldnt be too hard to fit.
Thanks, steve :D
PostPosted: Mon Apr 10, 2006 6:58 pm
Sunroof fitted. Thanks, for the advice guys. :D
