Heater not working
https://www.ausmini.com/forums/viewtopic.php?f=2&t=17077
Author:  sean [ Sat Mar 11, 2006 10:03 pm ]
Post subject:  Heater not working
Thinking about winter already - I want to get my heater working, at the moment it doesn't, What are the common faults to look for ?, The switch works, so does the control for hot, warm and cold, any thoughts on what to check ?
PS it is also good to put heater on when car is running hot in warm weather to help take away some of the heat.
Author:  Namibian CAMEL [ Sat Mar 11, 2006 10:16 pm ]
Check if all your hoses are whole,
I have never had a complete demister due to a buggered and now non-existant hose,
So do that
i actually dont have any heater at all as heater man is broken
Author:  min13k [ Sat Mar 11, 2006 10:47 pm ]
sean it will more than likely be the vaulve they get full of crud and although you can move the switch the butterfly stays shut depending on what car you have is as to were the tap is
makka
Author:  gafmo [ Sun Mar 12, 2006 6:13 am ]
I agree with Makka so just take it off and fit the hose directley
and it could also e the little radiator is blocked
yes if you are over heating it does help to put the heater n, if it working
