It is currently Tue Aug 12, 2025 10:04 pm
 Post subject: Fuel Problem
PostPosted: Fri Mar 10, 2006 6:44 pm
Gday all
i have replaced the fuel pump on cracker (electric) because the engine was being starved of fuel and it seemed as though the old fuel pump wasnt working but when i went to start it still the same problem the engine was being starved of fuel again. there is definetly fuel in the tank, there is no blockages anywhere between the tank and the pump, the carby works fine and the starts engine when i give it petrol manually. the only things i can think of are an electrical fault, blocked fuel filter (that i cant find anywhere!) or a blocked fuel line between the pump and the carby. can you give me some advice please as i have no other ideas.
No fuel comes out of the line at all at the top near the carby.
I cant find the fuel filter anywhere- i have followed the line from the tank to the carby
The fuel pump isnt pumping fuel or trying to
so i am guessing it is an electrical fault of sorts :evil:
any ideas much appreciated
PostPosted: Fri Mar 10, 2006 6:46 pm
There is a strainer on the end of fuel line in tank, could be blocked with crud.
Also check the little breather hose from top of tank (in boot) is not blocked.
PostPosted: Fri Mar 10, 2006 7:10 pm
the fuel line isnt blocked between the tank and the pump
The pump still wouldnt run with a live wire for mthe battery to the pump
does anyone know where i would find this invisible fuel filter :lol: i cant find it anywhere
so i am off to check fuses
PostPosted: Fri Mar 10, 2006 8:31 pm
the fuses are fine .
The pump still isnt pumping and i have no idea why :?
any ideas???
PostPosted: Fri Mar 10, 2006 10:00 pm
so the new pump is fine, this leaves wiring :x
this is what i was dreading :cry:
PostPosted: Mon Mar 13, 2006 6:05 am
So the pump isn't running? Have you measured the current to it? I have a 12V dry cell battery which I connect up with small jumper leads to power components to eliminate causes of gremlins. Try borrowing a multimeter and tracking down where the system falls over. Maybe fit an external fuel filter while you're down there.
PostPosted: Mon Mar 13, 2006 8:02 am
hi
we used a multi meter and found the problem. it was postive earth not negative so that is where we went wrong
PostPosted: Mon Mar 13, 2006 9:01 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
he he he he kids
makka
PostPosted: Mon Mar 13, 2006 9:05 am
hey atleast we figured it out :lol:
PostPosted: Mon Mar 13, 2006 6:08 pm
hehehe..its only two wires
Users browsing this forum: 1071 S, Bing [Bot], norton and 309 guests
