It is currently Mon Aug 11, 2025 5:04 am
 Post subject: Lots of Revs
PostPosted: Mon Feb 13, 2006 6:48 pm
A friend of mine has a 1275 MG Midget that when he starts it, immediately runs up to the redline without his foot anywhere near the accelerator pedal. He's had the twin 1-1/4"SU's apart a number of times searching for anything bent, sticking or binding without finding anything obviously wrong.
Any Ideas????
Diecast
PostPosted: Mon Feb 13, 2006 6:58 pm
is the accel cable sticking?
PostPosted: Mon Feb 13, 2006 7:00 pm
Don't pull the choke too far out?? :?
Lillee - 1969 Morris Mini K
PostPosted: Mon Feb 13, 2006 7:09 pm
Stuck Mechanical Advance ?
Hmmm, had that once..... combination of crap carb and clapped out dizzy.....
Sorry, cane be more specific... that part of the brain is fried...
J
PostPosted: Mon Feb 13, 2006 7:11 pm
does it come back down again?
if it doesn't then you've gotta assume the carbs are stuck open - cable stuck, or the linkages jamming
if it does come down again, then check for a (big) manifold leak
PostPosted: Mon Feb 13, 2006 7:39 pm
Has it only just started doing this ? Has it sat for a long time or just developed this progressively . Do the rev's drop soon after and has he been able to drive it normally if they do , in otherwords does it just spike on starting and then behave ?
PostPosted: Mon Feb 13, 2006 8:31 pm
It probably has those late throttle butterflies with the little spring loaded valve in them. Maybe one is stuck or bent...?
PostPosted: Mon Feb 13, 2006 8:40 pm
A soldering iron will fix that! :wink:
PostPosted: Mon Feb 13, 2006 10:58 pm
probly just a sticky throttle cable
could also be a loose carb linkage, then jams a bit on the side
could also be a sticky choke cable not letting the "high Idle Mech" back properly
could be a leaky or cracked manifold
could be a,,,,
will i gon on & on & on & On like i normally do, or should i just shut up ???
PostPosted: Mon Feb 13, 2006 11:32 pm
Not knowing much about that car, but could the cable be on the wron way around, so when he puts his foot down, the revs drop???? otherwise look at what the others have said, and i will crwal back in a hole somewhere :roll:
If only milk and orange juice is meant to come in 2 litres, only cheap wine comes in 5 litres...
http://www.flickr.com/photos/13922833@N04/
PostPosted: Mon Feb 13, 2006 11:51 pm
Everyone else has had their two bits, so here's mine:
There could be a hole in the Pollution Control Valve diaphragm or maybe in the brake booster.
Do midgets have either of these?
PostPosted: Tue Feb 14, 2006 6:03 am
As far as soldering - I tried that on one of those valves. Could NOT get the solder to stick....what am I doing wrong?
PostPosted: Tue Feb 14, 2006 8:05 am
float level(s) might be too high.
Website: www.justanothermini.com
PostPosted: Tue Feb 14, 2006 8:21 am
Smac, to get it right you need to "Tin" the area first
ask a professional solderer to help you, it`s easy once you know how.
PostPosted: Tue Feb 14, 2006 9:06 am
Must heat up the surface you want to solder to and melt the solder with that, not just melt it with the iron and drip it on - that's when you'll get "dry" joints - ie solder not sticking.
Bob Slattery
