1380 info needed... https://www.ausmini.com/forums/viewtopic.php?f=2&t=1724 |
Page 1 of 3 |
Author: | Jedi665 [ Tue Aug 31, 2004 1:24 am ] |
Post subject: | 1380 info needed... |
Hi all, Does anyone know /have a suggestion on which is the best carby set-up for a 1380? I've got a set of twin 1 1/4 SU's, but have been told these will starve the motor (it's not fitted yet). |
Author: | spathi [ Tue Aug 31, 2004 5:43 am ] |
I think the most common response might be a 45 Weber/Dellorto setup ![]() |
Author: | drmini in aust [ Tue Aug 31, 2004 6:38 am ] |
Or, if you can't stand the noise of Weber/Dellorto- a pair of HS4s, or single HIF44. |
Author: | Jedi665 [ Tue Aug 31, 2004 9:37 am ] |
Cheers guys, have to start looking now... What is the HIF44? Is that a later model 1 3/4"? What sort of prices should I pay for the different set-ups? |
Author: | dr trim [ Tue Aug 31, 2004 9:51 am ] |
makka is selling a hif44 with manifold and linkages and a K&N filter for $250 that's a good price. i've been told a hif44 still puts out good power but much more fuel economic than a webber/dellorto/twin SU's. correct me if im wrong, i most likely am ![]() http://ausmini.tziworld.com/viewtopic.php?t=1632 |
Author: | Jedi665 [ Tue Aug 31, 2004 9:56 am ] |
Thanks Mike, I'll PM Makka. |
Author: | gafmo [ Tue Aug 31, 2004 10:10 am ] |
HIF44 ![]() |
Author: | Jedi665 [ Tue Aug 31, 2004 10:21 am ] |
Excellent, thankyou. There's a couple on eBay in the UK, so fingers crossed. I had a Weber on my Clubbie Van, but it was horrid, maybe because it was only a 1098... But it also used to drip petrol onto the headers, and I was told that was normal???!!! |
Author: | Lillee [ Tue Aug 31, 2004 11:48 am ] |
1380? Go a webber 45! ![]() ![]() |
Author: | Mike [ Tue Aug 31, 2004 6:14 pm ] |
As far as I gather if your fuel level is set correctly a sidedraft shouldnt drip. |
Author: | Anto [ Tue Aug 31, 2004 6:23 pm ] |
Fitting a fuel regulator can help stop duel dripping too, if you run a facet pump for instance. Pretty sure it helped stop the problem on Christoph's weber. |
Author: | Jedi665 [ Tue Aug 31, 2004 6:51 pm ] |
I've got an original electric SU fuel pump, can the flow be adjusted on that? |
Author: | gafmo [ Tue Aug 31, 2004 6:55 pm ] |
nope you need a regulator if required |
Author: | drmini in aust [ Tue Aug 31, 2004 7:14 pm ] |
Anto wrote: Fitting a fuel regulator can help stop duel dripping too, if you run a facet pump for instance. Pretty sure it helped stop the problem on Christoph's weber.
Shouldn't need a regulator with a Facet/TRW/Purolator solid state pump (the little square one), I've fitted many to Minis. If your Weber or Dellorto or SU is flooding with one of these pumps, I'd replace the carb's needle and seat.... like I did mine (Dellorto) 9 years ago.. ![]() |
Author: | Anto [ Tue Aug 31, 2004 7:33 pm ] |
When I was running the SU everybody told me my Facet pump would cause the carb to flood etc. Well, it never did, didn't leak fuel out the top of the float bowl. Never had a problem. My Dell'orto does leak, but that is a gasket problem which I haven't got round to fixing. |
Page 1 of 3 | All times are UTC + 10 hours |
