It is currently Wed Jul 23, 2025 8:13 am
 Post subject: whats it worth?
PostPosted: Mon Mar 20, 2006 4:50 pm
1275 block , head to fit, crank , camshaft, pistons clutch and flywheel housing, flywhel and clutch? i have this lying around in my garage.... im wondering if i should spend the money and get it built or sell as parts? or do i buy a shell and put my engine i have in my LS into another mini and build the original block up and put that into the LS?
I probably wont sell it as parts but want do pplz thinki should do .....azpart from giving it all away to the replier.
PostPosted: Mon Mar 20, 2006 5:06 pm
If you've got the room and it's greased up so it won't rust I'd say hang onto it for future use . If you sell it you'll probably come across the perfect car with a blown motor ..... If you keep it you may need to use it yourself for your existing mini or you might find something else to use it in , just remember that 1275's are going to becocme scarcer and more expensive the more years pass since they produced them anywhere , especially since people keep taking them out to monster capacities and supercharging them , good unmolessted blocks and internals will be hard to get .
