How to wire third gauge - Tacho https://www.ausmini.com/forums/viewtopic.php?f=2&t=17371 |
Author: | Gerard [ Mon Mar 20, 2006 8:45 pm ] |
Post subject: | How to wire third gauge - Tacho |
Hi all I am wondering if somone can help before I took out the triple gauges out of my car (actually I think it was before I took out the 998 and put in the 1275) the Tachometer worked .... Now since I have had had the gauges out I have a green wire that disappears into the abyss of harness - can anyone tell me where this wire would go to I want to get the gauges working before I put in the new dash. Jack Read said that there should be a white wire that splits to plug into the tacho - (which I have found a white loop) but when I open that loop the car will not start ..... Anyone got any ideas??? Cheers Gerard |
Author: | Maxi23 [ Mon Mar 20, 2006 8:47 pm ] |
Green wire on my aftermarket tacho went to the coil if thats any help ? |
Author: | Marvin [ Mon Mar 20, 2006 8:48 pm ] |
Other than the main wire plug the only other cable should be a white with black stripe that connects to the tacho. |
Author: | Gerard [ Mon Mar 20, 2006 8:49 pm ] |
Ta - I thought that was where it went too a few green wires under the bonnet (I changed the coil in the upgrade to a pulsar dizzy - any ideas whether positive or negative???) cheers Gerard |
Author: | Maxi23 [ Mon Mar 20, 2006 8:52 pm ] |
Mine went to Negative |
Author: | Marvin [ Mon Mar 20, 2006 8:54 pm ] |
White/black strip wire goes to -ve coil |
Author: | hutto [ Mon Mar 20, 2006 8:56 pm ] |
green- to neg of coil red- to power/fuses white- lights black- earth/ body of car i think thats it isnt it ![]() |
Author: | Maxi23 [ Mon Mar 20, 2006 8:56 pm ] |
Yup, Thats it. |
Author: | Gerard [ Mon Mar 20, 2006 8:57 pm ] |
thanks guys |
Author: | hutto [ Mon Mar 20, 2006 9:03 pm ] |
easy as....... ![]() |
Author: | sean [ Mon Mar 20, 2006 10:19 pm ] |
Just put a post up about this should I follow the same colours ? |
