It is currently Sat Jul 19, 2025 7:31 am
 Post subject: front suspension
PostPosted: Tue Aug 31, 2004 9:33 pm
Stripped my front subframe tonight. Noted the following:
Both tie bars are bent. Should they be dead straight or have a slight warp in them? if they should be straight, how do they end up bending?
The front cones look fooked. They are squashed flatter than the rears. I think Kev has already said that you can use rears on the front. Is that right?
Also, there are rubbers on the front subframe that look like either bump stops or returns. The sit under the upper arm. Whats the correct name for these? Mine are absolutley FUBAR!
Cheers.
PostPosted: Tue Aug 31, 2004 9:40 pm
Yeah those are the bump stops under the upper arm. They have a habit of disintegrating - I don't think mine has any at all (unless that's just a hydro thing!)
PostPosted: Tue Aug 31, 2004 9:50 pm
so should i replace them or not bother?
PostPosted: Tue Aug 31, 2004 9:54 pm
You may as well they shouldn't be expensive. On the other hand they are only useful if you have a habit of getting your car airborne!
PostPosted: Tue Aug 31, 2004 9:58 pm
yea thats what I thought. The last owner of my clubby must have thought he was the dukes of hazzard!! :lol:
What about the tie bars being bent? Is that right?
PostPosted: Tue Aug 31, 2004 10:22 pm
Tie bars are supposed to be straight.. they get bent by people towing on them, or jacking under them.
Best way to straighten I reckon is take off, put in a vyce, apply judicious use of BFH until it looks straight.
Or go buy adjustable ones, they're thicker... :lol:
<edit> rubbers under top arm are called rebound rubbers. If not there it can put more load on the shock mounts, when you get big air... :cry:
PostPosted: Tue Aug 31, 2004 10:24 pm
JAM U are putting your Clubby back to original. If the Tie Bars are bent, You may be it is LOL but they should be straight. If you wish to do a comparison againest my Heavy Duty one's New and see how out your's are you have untill tomorrow.
Lock down in the House, I hate the the all these girls that will b around me LOL
PostPosted: Wed Sep 01, 2004 12:37 pm
Jim ya smart ass....... :lol:
OK Kev, a vice and BFH it is. When I held them side by side I knew something wasn't right, because they were both bent differently.
Went to Heritage MG this morning and bought the rebound rubbers for $6.50 each. :wink:
Will have to take a run to Pick 'n Paymore for some cones. I am sure my front ones are stoofed.
That about covers it. Cheers guys.
PostPosted: Wed Sep 01, 2004 10:16 pm
Anton,
when i did up the Mini Minor front end years ago, both tie bars were bent, so i got some straight 2nd hand ones, put some clubman van rear cones in the front, also the left knuckle had worn through the nylon cup in the upper arm, and ground into it. I got new knuckles for the trumpets, new nylon cups, and i had to add some weld to the hole in the upper arm and then grind it to shape before i put the nylon cup back in. i also replaced the needle roller bearings in the inner end of the upper arms, and the rubber bushes in the lower arms, and at the front of the tie bars. The ball joints were renewed while i was at it. i painted the subframe red and the suspension bits white (i was a real ricer in my youth). It handled like a brand new car after that.
I still have the original bump stops, but i will have to cut them down a bit, because i have put hilos in and sometimes it rides onto the bump stop which is a little uncomfortable.
So don't forget to check all that stuff i mentioned :)
michael
PostPosted: Thu Sep 02, 2004 9:18 am
Got it all covered Michael!!
I bought all the rubber bushes a few weeks back and I have 2 brand spankin new knuckle joints from way back (a stoopid ebay purchase ages ago)
The whole front end will be brand spankin new, so I look forward to that first corner when its on the road..... :wink:
PostPosted: Thu Sep 02, 2004 10:40 am
......and then the first tree when it understeers off the road :wink:
PostPosted: Thu Sep 02, 2004 11:12 am
...in a Mini?? pffffffft...as if!! :lol:
