It is currently Sat Aug 16, 2025 1:50 pm
 Post subject: Clacking CV?
PostPosted: Sat Mar 25, 2006 2:29 pm
Ok..what's the go with CV's if they clack in a straight line? If i drive slowly with my window down i can hear a clacking sound from the hub area..
They were replaced less than 12months ago..how long do they normally last?
PostPosted: Sat Mar 25, 2006 2:41 pm
A lot longer than that, assuming you used new ones. Check the boot hasn't split or come off and let lots of nasties in. Also check your wheel bearing, it may be this that's making the noise.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Sat Mar 25, 2006 2:43 pm
Yea they were new..
I got two new CV's..and new timken wheel bearings all round...I'll check the boot..
PostPosted: Sat Mar 25, 2006 6:00 pm
Elmo was doin the same thing for a while,,,, but then mysteruioulsy stopped..
he only does it now on hot days... i have no idea :?
PostPosted: Sat Mar 25, 2006 6:05 pm
As you have Honda brakes and those old original pads, it could be them rattling around..
Fit that new set... :wink:
PostPosted: Sat Mar 25, 2006 6:09 pm
Cool...it couldn't be the fact that my car is jacked up so high putting permanant stress on CV?
PostPosted: Sat Mar 25, 2006 6:28 pm
Yeah well the driveshafts are hardly straight now, hey!
If near new they should be quiet for many years, it's the dried out grease than makes them clack.
Mine are now 36 years old, worn, repacked 10 years ago, still quiet. :wink:
Users browsing this forum: No registered users and 375 guests
