Unseizing a Seized engine
https://www.ausmini.com/forums/viewtopic.php?f=2&t=17555
Page 1 of 3
Author:  CJ_DT [ Sun Mar 26, 2006 10:41 am ]
Post subject:  Unseizing a Seized engine
Hello,
I have a aquired a motor (non mini but that doesnt matter) that is seized, at some stage in the last 25-30 years where it was sitting in a shed, somehow water has gotten into the cylinder, I pulled the head, and the bore had some surface rust, but came up fine after a sand with wet rub, however the piston is seized in the bore. I assume that its due to the rings rusting to it, but is there any sure fire way of unseizing the little sucker, or is it a bin job? Its currently got a mix of diesel, canola oil and WD40 sitting in the bore above the piston, but because its a 2 stroke, it seems to be able to leak out of the damn holes aorund it faily quickly.
Chris
Author:  dodge [ Sun Mar 26, 2006 10:55 am ]
ur doint the right thing, after a day or two with WD40 , split the casing and pull out the crank, rod assembly
Author:  dodge [ Sun Mar 26, 2006 10:56 am ]
being a 2 stroke i would say its a big end ..
Author:  Joe [ Sun Mar 26, 2006 11:30 am ]
might be a good idea before you pull the crank out to try every couple of days after topping it up with crc/oil/whatever to rotate the crank, forwards, backwards etc... to unsieze my midget motor I put crc and oil in the bores and rocked the car while it was in gear...
Author:  CJ_DT [ Sun Mar 26, 2006 12:13 pm ]
I will keep doing what I am doing then, and resist the urge to start belting the living hell out of stuff with a sledge hammer, sadly patience is not one of my strong points.
Thanks Guys
Author:  Joe [ Sun Mar 26, 2006 12:32 pm ]
thats a good idea :)
can get a large breaker bar + socket on the end of the crank and get some movement out of it?
Author:  drmini in aust [ Sun Mar 26, 2006 1:11 pm ]
I've got the same prob with a Honda CB750 that was parked in a shed for 9 years. I've had WD40, then oil in the bores 6 months now, bugger still won't budge.
I put a torque wrench on the crank bolt at alternator, gave it 50lb/ft to rock it and still no turn over. Crank does rock a poofteenth.. :cry:
Ah well looks like motor out, head off, block of wood and a BFH needed... :lol:
Author:  dodge [ Sun Mar 26, 2006 1:43 pm ]
try to diesle flush it too.
Author:  Joe [ Sun Mar 26, 2006 5:39 pm ]
dodge that picture is hypnotic
Author:  TurboOrangie [ Sun Mar 26, 2006 6:37 pm ]
After reading that molasses trick in a post earlier today I think I'd give that a try.
Author:  Morris 1100 [ Sun Mar 26, 2006 6:48 pm ]
Molasses is very thick. Maybe vinegar would work better?
I have used vinegar on slave cylinders that the pistons were seized so tight that you could not move the piston with a hammer. After a few days in vinegar the pistons came out.
Heat is also another thing to try. If you have access to a hot water hose (I have a Kerrick hot water pressure washer) you can heat up the cylinder and it will expand a little so that you may be able to move the piston. If it is a single cylinder engine you may be able to heat it up in the laundry tub. :wink:
Author:  drmini in aust [ Sun Mar 26, 2006 6:52 pm ]
I wouldn't try molasses in most motors to unseize them, they have aluminium pistons, and molasses eats it.
use molasses only on iron and steel parts....
Author:  Hagar [ Mon Mar 27, 2006 7:18 am ]
Park it at the top of your sloping driveway pointing at the house , leave it in gear, handbrake off. Motor will defininitely un-sieze. Guantareed. :evil:
(yes, I know you said it's a mot a mini - but a two stroke engine)
Author:  cush [ Mon Mar 27, 2006 8:16 am ]
Post subject:  Re: Unseizing a Seized engine
CJ_DT wrote:
Hello,
just it does bloody matter.....
it means that this post shouldn't have been in Mini Chat
:roll:
Author:  sports850 [ Mon Mar 27, 2006 2:49 pm ]
Digressing slightly , I had a series 1 landrover with a similar problem , leaving it sit with wd40 etc in the bores didn't do any good till a mate came up with the bright idea of taking the sump off , turning it upside down and putting the wd40 mix in from the underside as well . It'd had a week sitting right side up with it supposedly seeping down from the top followed by a few days upside down with it seeping the opposite way . It must have met in the middle because it turned over easy after that . All we could come up with for a theory was the rings had rusted in so well that the mix could penetrate the top set but not any further , putting it in from upside down meant it got through all of the rings . Good luck .
Page 1 of 3 All times are UTC + 10 hours
