It is currently Wed Aug 06, 2025 10:18 am
PostPosted: Sun Mar 26, 2006 5:54 pm
Help/information required.
Does anyone have pictures of the reinforcements done by Crayford when they built their convertible Minis...
I have searched the net and have found heaps of pics of the car, but nothing about the actual work they have done to the reinforcing of the car. I am trying to work out the requirements for strengthening the floor of a Mini (for the new convertible) to ensure that its strong enough if there is no roof.
Cheers...!!!
PostPosted: Sun Mar 26, 2006 7:27 pm
Drive out to mini and Moke world and look at a mini miami
steve
PostPosted: Sun Mar 26, 2006 7:33 pm
does this help
http://www.rover2.ru/epc/r/122261
PostPosted: Mon Mar 27, 2006 3:51 pm
I'm in the middle of restoring my Heinz Hornet and all the reinforcements are out of the shell. Do you want dimensions or photographs?
[email protected]
starchak.ca
tdcperformance.ca
PostPosted: Mon Mar 27, 2006 4:28 pm
Both please
Building convertable aswell. After the untimely death of our Elf due to young 17 year old driver doing an illegal u turn
steve
PostPosted: Mon Mar 27, 2006 8:57 pm
:O Marcel..!!!! I have been studying your website like a hawke. I am very very very envious of the work that you have been doing. ANy additional pictures, advice, ideas, plans, etc etc would be an awesome start to things. I am FINALLY going to be working on a Mini so i am MOST excited..!!
PostPosted: Mon Mar 27, 2006 10:59 pm
yes that website is AWESOME!
go here people for a great read! and great pics!
http://www.starchak.ca/
PostPosted: Tue Mar 28, 2006 2:34 pm
Please excuse the excruciatingly disgusting state of the shell but this is the way I got it. This is the essence of what Crayford did:
The inner sill is reinforced with a box section of 1/8" plate welded and bolted in place which in turn is welded and gusseted into a vertical reinforcement up the A post and tied into the dash pan. The sill reinforcements are bolted into the rear companion bin inside which is another piece of reinforcing welded onto the upright part of the inner sill. Across the rear seat pan is another 1/8" plate boxing in the area under the seat. On the other side of those bolts is a small channel section to spread the load throughout the floorpan and inner wing.
It's difficult to see those parts in this photo but that's what I have at the moment. I have to dig out the bits to make drawings so they can be remade. I'll post some better photographs and dimension drawings on the weekend. Stay tuned...
[email protected]
starchak.ca
tdcperformance.ca
PostPosted: Wed Apr 05, 2006 11:09 am
Here's a sketch of the reinforcement cross sections. The top left is the sill reinforcement, the bottom left is the A panel upright and the one on the right is the section welded inside the compaion bin. I'll post some pictures to go along with these when I get the things made up and I'm fitting them to the shell.
The panel boxing in under the seat pan is pretty straight forward, but you'll get a picture soon anyway.
[email protected]
starchak.ca
tdcperformance.ca
PostPosted: Wed Apr 05, 2006 11:17 am
Thank you very much.
steve
PostPosted: Mon Apr 24, 2006 4:32 am
The new parts being trial fitted. This should give you a better mental image of how the reinforcing was done
[email protected]
starchak.ca
tdcperformance.ca
PostPosted: Fri Apr 28, 2006 8:49 am
now THAT my dear friend is magic...! :shock:
I have started the work on my little convertible now
http://www.ausmini.com/forums/viewtopic ... 179#251179
i am fortunately only on the easy stuff now. I think that anyone can strip a car..!!
PostPosted: Fri Apr 28, 2006 3:06 pm
Lookin good Marcel, but i thouroughly expected that you`d do the job a bit better than that... thought you might have actually made up some form of press device to enable the panels to have that original rolled/pressed look rather than that non-original sharp folded look
ah well,,,just keepin an eye on you buddy, someone has to toe your bum now & then hey?
just pickin on ya mate :-)
well done! & keep up the good work
