1275 cam choice https://www.ausmini.com/forums/viewtopic.php?f=2&t=17575 |
Author: | Benmcf1 [ Sun Mar 26, 2006 8:08 pm ] |
Post subject: | 1275 cam choice |
What would be the most recomended cam for a lively, daily use 1275? Local mini shop says, i think its 276? agree? disagree? What do ya think? |
Author: | Spaceboy [ Sun Mar 26, 2006 8:18 pm ] |
yeah the stock cam is the most suitable for daily driver use, the "fast road" cams enable hoonage, but most of the time in traffic you're doing less than 3000rpm.. the re-13 cam is probablythe way to go i like the sound of the sw5 |
Author: | drmini in aust [ Sun Mar 26, 2006 8:19 pm ] |
Tried those before, I reckon a Russell Engineering RE13 is the go now. ![]() At our last dyno day, around 1/2 the Minis there had one in. Including mine. ![]() Although I'm now running an RE282 in the 1360. It has a bit more mid and top end, not as good down low though. |
Author: | dodge [ Sun Mar 26, 2006 8:28 pm ] |
u can use a 276 and 1.7 rockers good all rounder |
Author: | Benmcf1 [ Sun Mar 26, 2006 8:29 pm ] |
Cheers Spaceboy, Doc. Thats two RE13's. I like the sound of the 282 though. not the sound (thub, thub, thub) but the sound, If you know what i mean ![]() Keep em cuming Hey spaceboy..... trafic shmafic, change down, make noise, annoy people..... yes yes |
Author: | Benmcf1 [ Sun Mar 26, 2006 8:32 pm ] |
Thanks hypnotic dodge..... 1.7? not heard of those i shall investigate. |
Author: | drmini in aust [ Sun Mar 26, 2006 9:47 pm ] |
Keith Calver reckons 1.7s only work on SOME race motors, too much lift for anything else. See http://www.minimania.com/web/SCatagory/ ... ticleV.cfm I run 1.5 forged ones in my 1360, and 1.46:1 Toyota Corollas in Barney (1293A+). They do give more top end performance, with a bit of torque penalty at low rpm. I can live with that.... ![]() |
Author: | Mick [ Sun Mar 26, 2006 10:02 pm ] |
I think they help with run-on a little as well. At least with my car they did.... |
Author: | Benmcf1 [ Sun Mar 26, 2006 10:03 pm ] |
So Doc with that in mind. To put in a 1.5 rockers for torque and that low down pull, but the 282 cam for mid and high rpm push, would be a lively combo? Miniworld's: Keeping your mini alive 5. has a 286 cam as a 2000-7500 rpm range. Would your experience be simalar with the 282? Cos that sounds awful nice.... Sorry doc compleatly missed the message there...... Let me rethink that |
Author: | Mini Mad [ Sun Mar 26, 2006 10:07 pm ] |
a 282 will pull from 3000-8500+..definately nothing at 2000...but you'll have far more power from 3000 onwards than the 286.. |
Author: | willy [ Sun Mar 26, 2006 10:07 pm ] |
I'm going the RE13 in my 1310. I will give you the low down once its all built up and run in. Probably even give u a drive if you're lucky ![]() |
Author: | drmini in aust [ Sun Mar 26, 2006 10:09 pm ] |
Benmcf1 wrote: So Doc with that in mind.
To put in a 1.5 rockers for torque and that low down pull, but the 282 cam for mid and high rpm push, would be a lively combo? Miniworld's: Keeping your mini alive 5. has a 286 cam as a 2000-7500 rpm range. Would your experience be simalar with the 282? Cos that sounds awful nice.... Yes you could say the 282 is a 2000-7500+ rpm proposition. But neither it nor the 286 will pull properly or take full throttle (Weber/Dellorto) from 2000. They do get their finger out around 2800 or so. 1.5 rockers will give LESS torque down low, not more... ![]() I can live with the 282 but if you do much stop-start traffic driving, RE13 is nicer. My 1310 gave good power to well past 7500 with the RE13 and 1.5 rockers. |
Author: | Benmcf1 [ Sun Mar 26, 2006 10:14 pm ] |
Author: | Lillee [ Mon Mar 27, 2006 7:53 am ] |
Go an RE-13. 282 is far too big and lumpy for a road cam. It will be a very involving drive to keep the revs up every time you turn the key. RE13 is much more civilised yet can get you going when the need arises. i eill be putting one of these in the 1330 |
Author: | dodge [ Mon Mar 27, 2006 7:46 pm ] |
sorry got my ford ratios mixed with mini, standard mini is 1.3 so go to a 1.5 ratio |
