It is currently Wed Aug 20, 2025 9:53 am
PostPosted: Fri Mar 03, 2006 5:03 pm
ok so this morning i went to hop in the car only to find out that i had no clutch
so i thought to my self its about time i fitted the new master cylinder iv had sitting on the shelf,
ok well fitting it went as well as can be expected but tell me this how much air can be in the system iv been pumping the pedal for the last hour and a half and the airs still poring out
please is there something im missing here
ive been doing the pump pump release method of bleeding still never has it taken me this long to do before
help please Peter.
A almost Bog Stock 1977 LS
1969 morris mini panel van, a work in progress
PostPosted: Fri Mar 03, 2006 5:06 pm
High heel ninja
Get a small peice of rubber hose, put it on the bleed nipple, open the bleeder, put the other end into the master cylinder, then start pumping, you won't spill or waste any fluid it will just circulate in the system, it should take long to bleed it this way.
Doogie
PostPosted: Fri Mar 03, 2006 6:53 pm
ok thanks for the tip but im still pumping and still theres air argh.....
ill keep pumping the pedal for now
ta peter.
PostPosted: Fri Mar 03, 2006 7:00 pm
it must be faulty, normally u only need to pump up and bleed 3 times , or until its just pure fluid. did u check the cup is the right way
PostPosted: Fri Mar 03, 2006 7:18 pm
Doogie
Sounds stupid to me... I thought you have to let old fluid sit for about 24hrs till the tiny air bubbles are gone. Use new stuff, otherwise you're putting air straight back in..
PostPosted: Fri Mar 03, 2006 7:24 pm
ok well i didnt check any of that as i thought it would all be ok seing it is all new parts the only bit thats old is the metal pipe from the master cylinder to the flexi pipe
looks like i may be taking it apart.. :(
oh well thanks guys any other sugestions are welcome
ta peter.
PostPosted: Fri Mar 03, 2006 10:01 pm
High heel ninja
You may thing its stupid, but it works!!!
Doogie
PostPosted: Sat Mar 04, 2006 7:53 am
get to supercheap, and buy a one man brake/clutch bleed kit for less than 10 bucks. heaps easy and takes a couple of pumps :wink:
PostPosted: Sun Mar 05, 2006 11:15 am
Yep.....Doogies method works a treat :wink:
Bye
Rod Image
PostPosted: Sun Mar 05, 2006 11:26 am
So you replaced the master cylinder but the slave cylinder is still the old one and you still cant get it to pump up................................maybe it was not the master cylinder but the slave that is faulty just a thought :D
Jon
PostPosted: Sun Mar 05, 2006 4:23 pm
Probly just need to "prime" the cyl first, i always do it "off" the car first, fit a plastic bung/plug into the top , fit the cyl , then remove the bung/plug & fit the pipe,,,2 or 3 pumps later & it`s bled
The clutch master cyl doesn`t have the "slow return valve" fitted like the brake cyls do,,,so you may find that every pump you make, simply returns the same when you take your foot off bringing back with it the same air you were pumping out,,,so,,,to prime it, you`ll need to open the pipe/nipple, push peddle down, lock up the pipe/nipple, then release the pedal,,,then open the pipe/nipple, push peddle down, close pipe/nipple, then take your foot off again etc etc etc. That way each time you release the pedal no air can come back up the lines back into the cyl each pump.
Once you have fluid moving, then use the nipple on the slave only, & then -> put foot to floor& just very quickly "Open-shut" the nipple to only let a tiny bit out, do this a few times & Bob should be your Aunty
PostPosted: Sun Mar 05, 2006 6:30 pm
well the saga continues i have now pulled the master cylinder apart as well as the slave cylinder i even filled both with fluid before reassembly,
the frist two presses of the pedal were fine the it went back to nothing and started pumping air again
so now ive pulled the old master cylinder apart given it a clean and i may just pinch the seals from the new one and see if that works
and the slave cylinder is about 6 months old the only old part in the system now is the metal pipe
and yes i agree the supercheap one man bleeders are great i have two of them
any way off to pull it apart again
ta all Peter.
PostPosted: Sun Mar 05, 2006 6:38 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
hmmmmm something weird there
how long had the master cyl been sitting ????
was it open or did it have a bung in it ???
makka
PostPosted: Sun Mar 05, 2006 7:27 pm
it has been sitting for about 4 months with its bung in, and in its un opened box
so yes got me stuffed
any how gunna go and try fit the old one now and see what hapens
Peter.
PostPosted: Sun Mar 05, 2006 9:03 pm
well another 2 1/2 hours at it and still no luck time to get some more parts i think the mastercylinder seems to be working fine so i'll replace the slave and hopefuly that will get me back on the road..
Peter.
