It is currently Tue Aug 19, 2025 6:13 am
 Post subject: gearbox?
PostPosted: Mon Mar 27, 2006 5:11 pm
when i push the clutch in i get a whirring nosie whats wrong with my car this time?
Thanks Josh
PostPosted: Mon Mar 27, 2006 5:14 pm
Probably clutch throwout bearing , fairly easy to replace , just one of the mini design foibles ...... Unbolt the drivers side engine mount , disconnect the spring from the slave cylinder to the clutch arm , jack the drivers side of the engine up a bit , remove the 7/16th bolts around the clutch housing and take the big alloy clutch housing off (Just the first bit of it that has the clutch lever on it ) . The remove the clutch lever , undo the big bolt and take the shaft with the bearing out . Get the bearing replaced (put on with a press) and then reassemble and adjust the clutch as per the manual .
Users browsing this forum: No registered users and 153 guests
