It is currently Fri Aug 22, 2025 12:00 pm
 Post subject: Clubby doors on an 850?
PostPosted: Thu Mar 30, 2006 9:56 pm
Probably another noob question. Hopefully I'll run out of these kind of questions soon. This may be an extremely stupid question buit I was just curious can you put clubby doors onto an 850 or don't they fit??
PostPosted: Thu Mar 30, 2006 10:00 pm
The short answer is no.
The long answer is yes.
:? :D
PostPosted: Thu Mar 30, 2006 10:34 pm
The hinges and front edge of the door is the same, but the rear edge and latching mechanism is completely different. Worst of all, the B pillar is a different shape and cannot be easily modified to take the later doors.
If you want a roundnose front with Clubby doors, look for a '71 Mini K. They came from the factory that way. :)
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Thu Mar 30, 2006 10:39 pm
Gas axe, grinder & a welder can make anything fit :-)
PostPosted: Fri Mar 31, 2006 7:38 am
not sure how this was done. but on my austin i have aussie doors when they normally have 850 doors. so yes they can fit but i dont know how :wink:
PostPosted: Fri Mar 31, 2006 7:48 am
they were done by magic, i think..
PostPosted: Fri Mar 31, 2006 7:54 am
Later roudy doors fit on sliding window door bodies without drama's , the problem is the clubman doors had burstproof latches (a whole new argument ....) with very different striker plates on the B pillar/door frame . You could theoretically cut up a clubbie to get the section of the B pillar required but it'd be much easier to fit the wind up roundie doors , plus you won't have every mini "expert" telling you your cars wrong and it shouldn't have those doors .....
 Post subject: mini
PostPosted: Fri Mar 31, 2006 8:30 am
I put sliding doors on my Deluxe, Looks good, But what a pain in the arse. My 850 had wind-ups. But the clubbie doors are totaly differant (more safe) but differant as stated.
*Reasonable pricing
*I come to you..
Jay: 0431404607
