A good days work https://www.ausmini.com/forums/viewtopic.php?f=2&t=17742 |
Author: | feralsprint [ Fri Mar 31, 2006 3:59 pm ] |
Post subject: | A good days work |
Well I have just spent the day fitting the Midas with some of Matts( The Miniman) bling hilo's and rod change oil seals, also fitted new diff side case seals and gave it a full service and fixed the wiring for the reversing lights ![]() ![]() ![]() ![]() ![]() Thanks Matt all your bits fitted nice and easy just like they should Jon |
Author: | Lillee [ Fri Mar 31, 2006 4:06 pm ] |
No leak? how will you know if it's run out of oil? ![]() ![]() |
Author: | Blokeinamoke [ Fri Mar 31, 2006 5:40 pm ] |
Question: Is the body a fibregalss monocoque? or does it have seperate frame? Does it use mini subframes? The interior bits are they mini or other? I very impressed by what I see and I am just trying to increase my understanding of them. I am going to the OK soon so I will be in postion to inspect some and maybe bring one home. ..maybe... Good to hear it is going so well for you.. |
Author: | feralsprint [ Fri Mar 31, 2006 7:07 pm ] |
It is a bit of a worry not leaking oil but I am sure a few drives will fix that right up ![]() The body is a fibreglass monocoque and does not use any metal at all for the chassis, a mini front subframe is mounted to the body and a beam type axle in the rear using standard swing arms and coilover shocks in the rear. The interior does not use any mini bits with the dash panel actually being a MG Metro dash and the rest is all from Midas except the seats which are Cobra Jon |
Author: | gafmo [ Fri Mar 31, 2006 7:48 pm ] |
Do you have a thread on your Midas ![]() ![]() Oil leaks..they always find the next weakest spot ![]() |
Author: | feralsprint [ Fri Mar 31, 2006 8:56 pm ] |
I will start a new thread later on in galleries with pics and info for those interested Jon |
