On the way home from work tonight
all of a sudden i couldnt select 3rd
there was no bang, clunk or thud
it was almost like there was something blocking the gate
then when i got home and shut it down i tried to go throught the gears without the motor running and was able to select all 4
started her up again as was able to select third again
although first and third seemed a little bit sloppeier that it was this morning
any ideas on possible causes and best way to remedy im prety sure its the selectors and not the actual gearbox
i think its a remote change( long box like structure under floor from motor to gear stick)
Gadget.
mtsmini wrote:
Master, you are wise beyond your years.....I am a mere grasshopper before you
Tombo wrote:
Gadgets has never been so right
