It is currently Sun Aug 03, 2025 5:01 pm
PostPosted: Tue Apr 04, 2006 8:35 am
hi all,
well its come time that i need to change my door trims and i was thinking of having a built up section in the shape of the from morris badge with wings and then i was going to glue some material over it so it was all the one colour but the badge was raised.
my question is what sort of foam/material should i use for this raised section and how would i cut/shape it?
any info would be great
thanks all
100% Pure A Series Turbo
PostPosted: Tue Apr 04, 2006 2:15 pm
I had Rockford Fosgate done like that on a Parcel shelf at Brisbane Car Sound, they did it by laminating a couple of pieces of vinyl together and cutting it out with a pair of scissors and glueing this on under the vinyl and pressing it into the corners as you glued the upper layer in ...... I was thinking about doing the same sort of thing with 3mm mdf with the corners saded smooth....
Cheers Gerars
