It is currently Fri Aug 01, 2025 8:49 pm
 Post subject: Side strip things?
PostPosted: Sat Apr 01, 2006 5:46 pm
teh admin God
teh admin God
Okkher
so a long while ago i bought a few of these, as in this auction, they are the same actually,
http://cgi.ebay.com.au/MINI-CHROME-SIDE ... dZViewItem
Would someone be kind and tell me, if they have once previously also purchased some, and installed them successfully, how did you go about this?
They are curled up, and short of cutting them into a few pieces, i don't see that they are going tp be able to fit the car?
That is all. It's a very dangerous situation :?
Sir Namibian CAMEL of MONGOLIA !!!
Vrilen Snyson Racing: Finding us all a Vrilen
Asparagus: Experience the versatility
PostPosted: Sat Apr 01, 2006 6:58 pm
well, I've never done it myself... so you don't want my advice....
but they say you roll it on in the opposite direction to the way it's rolled up, and use something to heat it gently to get it into the tight spots..... leave it out in the sun for a while and use a hair dryer... ?
or PM Steve, he'd be a genius at it I'm sure
PostPosted: Sat Apr 01, 2006 6:59 pm
I thinkthe consensus is to heat them up either by some hot water in a bucket or sun or lightly with a heat gun which makes it more pliable..
You need to put them on the opposite way to the natural curve, it give it a nicer bend once on the car..kinda hard to explain though..
PostPosted: Sat Apr 01, 2006 8:08 pm
Now I remember why I like my Innocenti flares and straight black pinchweld in between.. 8)
Good luck.
Don't leave Mini in the sun, that plastic strip shrinks..... :lol:
PostPosted: Sat Apr 01, 2006 10:31 pm
I used a heat gun on low temp, rolled it the opposite way to its natural curve, then underneath the moulding drilled holes through it and into the seam of the car and fitted very small pop rivets, its really the only way to hold it in place!!! Especially when u have S type flares.... its even harder!!!!
Dont forget to use a big bag of patience also!!!!!
PostPosted: Sun Apr 02, 2006 1:36 am
Don't use a heat gun-Too hot!!
Go see your Mum-sister or girlie friend and borrow there hair drier.
Works a treat!!!
Then wash your hands.. :lol:
PostPosted: Sun Apr 02, 2006 1:46 am
LS1380 wrote:
..Then wash your hands..
why does he need to do that? :?
PostPosted: Sun Apr 02, 2006 8:10 am
A heat gun used wisely on low heat from a distance works a lot quicker then a hairdryer. It took me 2 full days to do both sides of the car......
PostPosted: Sun Apr 02, 2006 9:20 am
hmmm I like I like. Might grab some for the 850, do they look half decent on them? :).
Shard
PostPosted: Mon Apr 03, 2006 5:03 pm
Use the heat gun - carefully.........hair dryer has a safety switch off mechanism and takes ages to do one side coz. it keeps cutting out :evil:
Unless you have lots of time available, use the heat gun
Rod Image
PostPosted: Tue Apr 04, 2006 11:44 am
i had lots of issues putting these on my car a while back. everyone here is pretty much on the money, heat it up to opposite curve, when you put them on heat them up a bit too. the bastard areas are around the s flares (you have them yes?) and just above the rear wheel grease nipple cover, i actually cut the bottom away from that part on mine so i could get them on. dont do that, its hard, and they're pointy...
78 Leyland Mini - Prince
PostPosted: Tue Apr 04, 2006 12:45 pm
Bucket of hot water will work too. :D
PostPosted: Tue Apr 04, 2006 1:08 pm
I think we've all experienced the same fitting the side mouldings on. I too, had a number of issue fitting em. As previously mentioned Patience IS A MUST when fitting these.
If you do use a heatgun - only on very low heat, as I found out :oops:
They tend to "crimp up" around the wheel arches so watch-out for that. When I puchased mine, was told to leave them in the sun for a good half hour prior to fitting.
They look :D when their on though.
Good luck with it.
PostPosted: Tue Apr 04, 2006 5:13 pm
i had these fitted to my 850, and when I repaired the front I removed what I could of them. They had been glued on with sikaflex.
When I went for a rego check I was told that I needed to refit them as the mini now had sharp edges....
so I took the strips all off and went to another garage.
PostPosted: Tue Apr 04, 2006 5:29 pm
i chucked it all in a pile of near boiling water, kept the whole pile in the water and it unrolled as I put it on. worked great
